06-12-2010, 14:46 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: +919304287474 Age: 41
Member: 714710 Status: Offline Sonork: offline Thanks Meter: 1,017 | big problemes kp 199 only show on screen kp 199 i use com 1 cable resold on booard rx and tx i faced problemes COM1 [Serial0] selected module v3.14 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 3 sec Remove/Install battery now ! i try change rx and tx point but problemes not solved i use chinese mirical but problemes same pz hel me infinitiy team |
06-12-2010, 14:49 | #3 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
change cabel or use red power supplly cabel... | |
06-12-2010, 14:49 | #4 (permalink) |
Freak Poster Join Date: Jun 2008 Location: india Age: 41
Member: 792200 Status: Offline Sonork: [email protected] Thanks Meter: 64 | it is communication problem check cable then try again and use fully charged battery |
06-14-2010, 12:34 | #6 (permalink) | |
it's cable problem for sure. You must double check that you have used correct pinout. Also you can try to swap Rx <-> Tx wires. | |
06-15-2010, 06:46 | #8 (permalink) |
Member: 792200 Status: Offline Sonork: [email protected] Thanks Meter: 64 | it is communication problem dear friend as infinity team said that it is a cable problem or try to swap rx-tx if ur problem does not solved then dry sold ur board it will work for me many times |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Really big favour! | MiMiR the WiseMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-18-1999 03:21 |
