09-27-2007, 15:28 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: .:Planet Namek:.
Member: 189984 Status: Offline Thanks Meter: 112 | Big Unlock problem Mg160a... i have some problems first i try to unlock, but cant enter nck code... COM3 [VCP0] selected Device: LG MG160 Checking data, wait... Action: unlock read unlock codes Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL BRAZIL CLARO MG160b P16 FL 55 V10a 724-05 MAR 19 2007 +1 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20070926-181835.B1E.bin loading data... data loaded imei: 34523625423452300 Reading [eeprom-sec_34523625423452300]... file saved: backup_eeprom-sec_34523625423452300_20070926-181835.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 00108303 code: 0000000000000000 Finished, Remove/Install battery now ! Time used: 10 sec -------------------------------------------------- COM3 [VCP0] selected Device: LG MG160 Checking data, wait... Action: unlock direct unlock method #1 Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL BRAZIL CLARO MG160b P16 FL 55 V10a 724-05 MAR 19 2007 +1 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20070926-182015.B1E.bin loading data... data loaded imei: 34523625423452300 Reading [eeprom-sec_34523625423452300]... file saved: backup_eeprom-sec_34523625423452300_20070926-182016.B1E.bin backup critical area Done Check memory... loading data... data loaded loading data... data loaded loading data... data loaded loading data... data loaded code: 00108303 code: 0000000000000000 Check memory Done Write... Erasing: eeprom-sta Writing: eeprom-sta Write Done Finished, Remove/Install battery now ! Time used: 26 sec NOT WORK STILL LOCKED ------------------------------------------------ COM3 [VCP0] selected Device: LG MG160 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL BRAZIL CLARO MG160b P16 FL 55 V10a 724-05 MAR 19 2007 +1 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20070926-182113.B1E.bin loading data... data loaded imei: 34523625423452300 Reading [eeprom-sec_34523625423452300]... file saved: backup_eeprom-sec_34523625423452300_20070926-182113.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-sec Writing: eeprom-sec probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 11 sec NOT WORK STILL LOCKED -------------------------------------------------------- currently this is locked firmware, and try to reflash phone with other firmware... from support... after flash with fw from "claro" unlocked fw, enter unlock nck and unlocked successfull... now the problem is .... the mobile not find network ... see the pic.... some solution!!!! txz in advance some solution?? Last edited by samusprime; 09-27-2007 at 15:36. |
09-28-2007, 15:43 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Did you tried to select band ? Did you checked phone before unlock ? Is it was possible to make 112 calls w/o sim before unlock ? Where are you from and from what region (operator) you have got phone for unlock ? |
09-28-2007, 17:36 | #5 (permalink) | |
Member: 189984 Status: Offline Thanks Meter: 112 | Quote:
- yes but cant select operative band... 2945#*# and enter in Eng Mode, and select Change Frecuency Band, when push Ok button nothing happen... the mobile show signal but say LIMITED SERVICE Did you checked phone before unlock ? - yes i tested too after unlock Is it was possible to make 112 calls w/o sim before unlock ? - its possible make calls to 112... and change imei too and not work... still calls only 112.. Where are you from and from what region (operator) you have got phone for unlock ? - Colombia Operator Comcel, network 850/1900 - i unlocked sucessfully mg161 from Movistar colombia... this fw ask nck, just read code and enter manually, but comcel have a locked fw... not ask nck code.... reflashed with comcel fw MG160aP16FL-AM_MD2-V09b_XXX-XX_Mar-28-2007+0_firmware.B1M.bin MG160aP16FL-AM_MD2-V09b_XXX-XX_Mar-28-007+0_LP_En_Es_Pt.B1P.bin the mobile show signal but say Emergency Only, but make calls to 112, and restore original imei MG160aP16FL-57-V10a-732-101-Apr 11 2007+6 imei: 01132500082660000 Done Finished some solution?? txz for help | |
09-28-2007, 21:53 | #8 (permalink) |
Member: 189984 Status: Offline Thanks Meter: 112 | again.. i have another mobile currently locked Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Read info... software version: MG160aP16FL-57-V10a-732-101-Apr 11 2007+6 imei: 01117200494136900 Done Finished Read eeprom COM3 [VCP0] selected Device: LG MG161 Checking data, wait... Action: read eeprom Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL ** Central AM II ** MG160aP16FL AM_MD2 V09b XXX-XX Mar 28 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20070928-155025.B1E.bin loading data... data loaded imei: 01117200494136900 Reading [eeprom-sec_01117200494136900]... file saved: backup_eeprom-sec_01117200494136900_20070928-155025.B1E.bin Reading [eeprom-dyn_01117200494136900]... file saved: backup_eeprom-dyn_01117200494136900_20070928-155025.B1E.bin backup critical area Done Check memory... Reading [eeprom-complete]... file saved: backup_eeprom-complete_20070928-155026.B1E.bin Completed Finished, Remove/Install battery now ! Time used: 17 sec flash read COM3 [VCP0] selected Device: LG MG161 Checking data, wait... Action: read flash Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL ** Central AM II ** MG160aP16FL AM_MD2 V09b XXX-XX Mar 28 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20070928-155110.B1E.bin loading data... data loaded imei: 01117200494136900 Reading [eeprom-sec_01117200494136900]... file saved: backup_eeprom-sec_01117200494136900_20070928-155110.B1E.bin Reading [eeprom-dyn_01117200494136900]... file saved: backup_eeprom-dyn_01117200494136900_20070928-155110.B1E.bin backup critical area Done Check memory... Reading [flash]... file saved: backup_flash_20070928-155212.B1X.bin Completed Finished, Remove/Install battery now ! Time used: 80 sec |
09-29-2007, 16:47 | #11 (permalink) |
Member: 189984 Status: Offline Thanks Meter: 112 | here the fullflash readed http://rapidshare.com/files/59097409...155212.B1X.rar |
10-05-2007, 19:35 | #14 (permalink) |
Member: 189984 Status: Offline Thanks Meter: 112 | hello... i have another fw version... Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Read info... software version: MG161aP16FL-AM_MOV-V10a-732-123 APR 04 2007+3 imei: 01126600127226300 Done Finished flash readed and eeprom... COM1 [VCP0] selected Device: LG MG161 Checking data, wait... Action: read eeprom Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL ** MOVISTAR ** AM_MOV MG161a P16 FL V10a 732-123 APR 04 2 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20071005-133052.B1E.bin loading data... data loaded imei: 01126600127226300 Reading [eeprom-sec_01126600127226300]... file saved: backup_eeprom-sec_01126600127226300_20071005-133053.B1E.bin Reading [eeprom-dyn_01126600127226300]... file saved: backup_eeprom-dyn_01126600127226300_20071005-133053.B1E.bin backup critical area Done Check memory... Reading [eeprom-complete]... file saved: backup_eeprom-complete_20071005-133054.B1E.bin Completed Finished, Remove/Install battery now ! Time used: 21 sec --------------- COM1 [VCP0] selected Device: LG MG161 Checking data, wait... Action: read flash Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL ** MOVISTAR ** AM_MOV MG161a P16 FL V10a 732-123 APR 04 2 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20071005-133137.B1E.bin loading data... data loaded imei: 01126600127226300 Reading [eeprom-sec_01126600127226300]... file saved: backup_eeprom-sec_01126600127226300_20071005-133137.B1E.bin Reading [eeprom-dyn_01126600127226300]... file saved: backup_eeprom-dyn_01126600127226300_20071005-133137.B1E.bin backup critical area Done Check memory... Reading [flash]... file saved: backup_flash_20071005-133240.B1X.bin Completed Finished, Remove/Install battery now ! Time used: 73 sec ------------------------------------------------------------ now i try to unlock.... i will already posting.... |
10-06-2007, 01:56 | #15 (permalink) |
Member: 189984 Status: Offline Thanks Meter: 112 | after flash still locked!!!!! i flashed with files from pic... plzz help backup flashes here... http://rapidshare.com/files/60566090...133054.B1E.rar http://rapidshare.com/files/60566203...133240.B1X.rar |
F480 big unlock problem | .::allgsmkey::. | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 4 | 10-22-2008 22:59 |
unlock lg mg160a | maommb | PolarBox 3 | 3 | 02-01-2008 20:56 |
How to unlock LG MG160a ( MG160 ) ? | gsm_unlock2 | VygisToolbox | 7 | 05-28-2007 18:24 |
6020 Big Unlock Problem !!! | DaliborDu | Griffin | 3 | 09-11-2005 23:35 |
