Old 05-08-2008, 00:34   #1 (permalink)
lacasapc's Avatar
Member: 259133
Thanks Meter: 22
Thumbs up bird v788 unlock
hi, i have bird v788a to unlock,
do you think i can do it with v708 model selected,
or do you know any solution, besides this one?
Old 05-08-2008, 15:18   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What is phone CPU name and what is bottom connector type ?
Old 05-09-2008, 00:58   #3 (permalink)
lacasapc's Avatar
Member: 259133
Thanks Meter: 22
Originally Posted by InfinitySupport View Post
Hello,
how can i check the phone cpu name?,
the connector has 16 pins
Old 05-09-2008, 07:53   #4 (permalink)
Member: 130995
Hello,
Just open phone and see what is CPU chip name.
Also, you can try to select V708 model and try to read flash from your phone
keyboard top
1..........16
1: Gnd
9: Box Rx/Phone Tx (RJ45 pin 3)
10: Box Tx/Phone Rx (RJ45 pin 2)
16: Gnd
Old 08-07-2008, 21:48   #5 (permalink)
John(LMT)'s Avatar
Member: 507536
Thanks Meter: 75
Exclamation Unlock Bird V788a
Hello has anyone Unlocked this phone with infinity Bird V788a?, i have tryed to unlocked reading codes, and not luck and also tryed with Direct Unlock, but not success, is there any other method?, but i do not see this phone in List of Infinity sw.-
Thanks in advance!
..::Alfa-Gsm::..
Old 08-11-2008, 14:42   #6 (permalink)
Member: 130995
Hello,
What is the problem exactly ?
What was the problem during process ?
Old 08-23-2008, 16:05   #7 (permalink)
Member: 278411
saber como desbloquear con la se tool
me pueden dar una manita
Old 08-24-2008, 01:16   #8 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
Thanks in advance!
..::Alfa-Gsm::..
y u dont read flash via chinesemiracle or mmodule and send to support?
Old 09-13-2008, 16:22   #9 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
ok, just got v788 from cellink gtt wireless communication plus, pinout same as sagem flat 16 pin and read flash as v750 bird with mmodule v2.32 and sent to support, please make unlock and upload to support, tnx.
==== log: [9/13/2008 10:41:55 AM] ====
COM5 [VCP0] selected
Action: read codes
unlock method: read codes
Model: Bird-V750
Checking data, wait...
19200 autodetect
Initializing[6219:8B02:8B01]...
CPU: MT6219
chip: 0031:88C1:785A
CPU: MT6226MA detected
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226M,E02
Date: 2005.04.12
Version: 1.0
Version: V1.00.00_M080225GUY-V42-I05
Version: MK6227_06A_HW
44 byte(s) read
imei: 3573900*******
connection Ok
151 byte(s) read
Phone lock: Off
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 1234
Finished, time used: 12 sec
Remove/Install battery now !
it says locks off but its still network locked, pse check this, tnx.
The Following User Says Thank You to mrfixit For This Useful Post:
Old 09-13-2008, 16:25   #10 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
more detail of bird v788 here:
==== log: [9/13/2008 10:53:55 AM] ====
Device: Bird-V750
advanced flash detection disabled
eeprom backup enabled, it may takes several minutes !
Action: read NOR flash
Boot...
19200 fixed
Connecting, wait...
CPU: MT6219
boot step size: 0400
Boot Done
Initialize...
flash: 98007500000002:2BEA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.61FE5 373.[MZ2007B2_GUYANA_PCB01_GPRS_MT6226M_S01.V1_00_00_M0 80225GUY-V42-I05.BIN_F716D685].rpl
New firmware detected:
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 61FE5373
identification#1 protocol ver: 04
ver. sw1: MZ2007B2_GUYANA_PCB01_GPRS_MT6226M_S01.V1_00_00_M0 80225GUY-V42-I05.BIN
ver. sw2: V1.00.00_M080225GUY-V42-I05, 7A29E908
ffs offset/size: 01C00000/00400000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: flash[MZ2007B2_GUYANA_PCB01_GPRS_MT6226M_S01.V1_00_00_M0 80225GUY-V42-I05.BIN]_part_1_of_1...
file saved: D:\Program Files\InfinityBox\MModule\v788\flash[MZ2007B2_GUYANA_PCB01_GPRS_MT6226M_S01.V1_00_00_M0 80225GUY-V42-I05.BIN]_part_1_of_1_20080913-111022.B0X.bin
file saved: D:\Program Files\InfinityBox\MModule\backup_security\system_l og_61FE5373_MZ2007B2_GUYANA_PCB01_GPRS_MT6226M_S01 .V1_00_00_M080225GUY-V42-I05.BIN_F716D685_20080913-111345.B0X.bin
Finished, time used: 1185 sec
The Following 2 Users Say Thank You to mrfixit For This Useful Post:
Bird v788 unlock report and pinout diagram Orange_Dominica Infinity-Box 4 02-28-2009 19:10
As I unlock the Bird V788 records Various 0 07-23-2008 16:16
bird v788 unlock lacasapc Various 0 05-08-2008 00:37
Bird S1199 Unlock zoudash Infinity-Box 9 10-30-2007 16:28
Any Solution for Bird S199 Unlock/Flash ? powerusergpt Various 8 10-04-2006 07:21
Page generated in 0.22585 seconds with 9 queries
