Old 12-30-2010, 17:56   #1 (permalink)
coolshahul's Avatar
Member: 598334
Thanks Meter: 111
Lightbulb black cherry bl8000
infinity team please add black cherry models in shell , cant change imei, format, usercode.
Old 12-30-2010, 18:13   #2 (permalink)
Cheater -Don't Deal with him-
Member: 1050335
Sonork: 100.1602801
Thanks Meter: 4,174
..::Thanks for your feedback::..
RIZWANJAT
The Following User Says Thank You to RIZWANJAT For This Useful Post:
Old 12-30-2010, 22:07   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
We need to get some information about phone hardware:
1. What is this phone CPU chip name ?
2. What is phone bottom connector type, how many pins ?
Thank you very much in advance for information about this phone !
Old 12-31-2010, 14:08   #4 (permalink)
coolshahul's Avatar
Member: 598334
Thanks Meter: 111
cpu : mt6223DA
connector : micro usb 4pin
Old 12-31-2010, 14:15   #5 (permalink)
coolshahul's Avatar
Member: 598334
Thanks Meter: 111
COM75 [VCP0] selected
module v3.25
Action: "repair imei"
imei write method: mode-2
imei write channel: imei #1 for dual sim/mono CPU
new imei: 352353022566233
Model: Autodetect 6205-6239 NOR
Checking data, wait...
19200 autodetect
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:638C:000C
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: C2302_2.09A.W09.36.MP.V2
Version: AOXUN23C_09A_HW
detecting structure #2...
1 2warning: wrong packet cs
3 5warning: wrong packet cs
7 8 9 11 12 13 18 19 20 22 24 25 26 28 29 30error: detection failed (20 tries), read flash and send to support
connection Ok
1 2 3 5 7 8 9 11 12 13 18 19 20 22 24warning: wrong packet cs
error: can't read required data
error: operation failed !
Finished, time used: 12 sec
Remove/Install battery now !
Old 12-31-2010, 14:17   #6 (permalink)
coolshahul's Avatar
Member: 598334
Thanks Meter: 111
module v3.25
Device: Autodetect 6205-6239 NOR
imei write method: mode-3
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 98000300000001:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (07)
TCL-ID is absent
New firmware found (v.3.25, database date: 23.12.2010):
C2302_2_PCB01_GPRS_MT6223_S00.09A_W09_36_MP_V2.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 07
sw version: C2302_2_PCB01_GPRS_MT6223_S00.09A_W09_36_MP_V2.BIN
project-id: C2302_2.09A.W09.36.MP.V2, 00000000
code offset: 00000000
ffs offset/size [02]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
detecting startup code area #2...
startup code area #2 is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: C2302_2_PCB01_GPRS_MT6223_S00.09A_W09_36_MP_V2__ff s...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\C2302_2_PCB01_GPR S_MT6223_S00.09A_W09_36_MP_V2__ffs_20101231-184628.B0E.bin
Backup required data Done
====> Patch required data ...
imei is not detected !
What to do:
1. Power-On phone
2. wait 20-30 sec
3. Power-Off by "Power" button, don't remove battery !
4. Repeat "imei" procedure again
If imei can't be detected:
1. make "complete" ffs/eeprom format
2. Power-On phone
3. wait 20-30 sec
4. Power-Off by "Power" button, don't remove battery !
5. Repeat "imei" procedure again
If imei can't be detected: read flash and send to support: [email protected]
Patch required data Fail
Finished, time used: 2 min 40 sec
Old 12-31-2010, 14:36   #7 (permalink)
coolshahul's Avatar
Member: 598334
Thanks Meter: 111
MM module , selected same cpu model doro410s, result same
module v3.71
new imei: 910535602528741
Model: Doro-PhoneEasy-410s
19200 autodetect
CPU: MT6223
status: FF
Date: 2000.00.00
Version: 1.0
80 byte(s) read
imei: 00001000002C10
connection Ok
80 byte(s) read
verification...
error: verification failed
what to do:
1. be sure that you have full flash backup for emergency case
2. make "format ffs" in "complete" mode
3. power-on phone
4. power-off phone by "Power" button (DO NOT remove battery)
5. repeat current operation
Finished, time used: 11 sec
Old 12-31-2010, 14:47   #8 (permalink)
coolshahul's Avatar
Member: 598334
Thanks Meter: 111
Here's the full flash backup for balck cherry bl8000 model
C2302_2_PCB01_GPRS_MT6223_S00.09A_W09_36_MP_V2__fu llflash_20101231-190254.B0M.bin - 4shared.com - online file sharing and storage - download
Old 01-01-2011, 16:38   #9 (permalink)
coolshahul's Avatar
Member: 598334
Thanks Meter: 111
infinity team waiting for ur reply
Old 01-03-2011, 14:07   #10 (permalink)
coolshahul's Avatar
Member: 598334
Thanks Meter: 111
no reply???????????????
Old 01-06-2011, 13:58   #11 (permalink)
coolshahul's Avatar
Member: 598334
Thanks Meter: 111
Will i get reply?????
Old 01-06-2011, 18:41   #12 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what result you get with IMEI change mode-1 ?
did you try to change IMEI over bluetooth?
IMEI change without cable over Bluetooth link step-by-step tutorial - GSM-Forum
Old 01-07-2011, 14:47   #13 (permalink)
coolshahul's Avatar
Member: 598334
Thanks Meter: 111
IMEI mode-1 is my first prefrence always, in this case phone not work, so i tried other work.
k i'll try bluetooth option and will post log.
Old 01-08-2011, 13:22   #14 (permalink)
Member: 148515
hello!
if IMEI is changed and you can see this via *#06#- then it is no point to try it change using different methods. They all do same. Check if you can see networks in phone menu, if not- it might be not supporting your network frequency
M35i v21 with black square... laxxe x1x to x45/x50 5 01-20-2002 22:01
Nokia 3330/4.30 Just black screan after flash GSM_Andy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-20-2001 23:31
V3688 black screen. Mod Motorola Old Legacy (EMMI) 0 09-24-2001 21:13
5110/6110 Black Torx Screws pks Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 05-06-2001 01:43
why so much battle with black listed phones? Zianna Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-06-2001 16:10
Page generated in 0.24624 seconds with 9 queries
