10-25-2017, 15:59 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | blackview a7 frp.... Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 77 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847346132A52150A00544A1 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! i try it to remove frp but not done....i read on forum but not find any solution...can one help me....thank you |
10-25-2017, 16:48 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | THEN YOU WILL NEED TO CHANGE DA FILE IN BOOT FOLDER HERE IS YOUR DA FILE LINK : https://drive.google.com/open?id=0Bw...GN6MWtlZUF1cFE GOOD LUCK |
The Following 2 Users Say Thank You to gracy_elec For This Useful Post: |
10-25-2017, 17:39 | #5 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | thank you brither i try it and with this file bute the same ..... i read on forum and i replace MTK_AllInOne_DA_SP but not have succes |
10-25-2017, 18:13 | #6 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | solved i used DA_SWSEC from Sp as MTK_AllInOne_DA_SP and all ok Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2017-07-19.22:57 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847346132A52150A00544A1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4G8 [eMMC] : FLASH_CID : 90014A483847346132A52150A00544A1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x354F6386C0ADFD85309426A79D49F8E2 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Blackview ProdName : A7 ProdModel : A7 Device : A7 AndroidVer: 7.0 MTKxCPU : MT6580 MTKxPRJ : A7-Blackview-V0.8-20170802 SECURITY : IMEI_SW [1] : 352449090457907 IMEI_SW [2] : 352449090457915 BTMAC Addr : DE2546658086 WiFi MAC : 000000000000 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2017-07-19.22:57 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847346132A52150A00544A1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4G8 [eMMC] : FLASH_CID : 90014A483847346132A52150A00544A1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x354F6386C0ADFD85309426A79D49F8E2 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to genci titi 2002 For This Useful Post: |
11-29-2017, 16:17 | #8 (permalink) | |
Insane Poster Join Date: Jul 2013
Member: 1988604 Status: Offline Thanks Meter: 17 | Quote:
11-30-2017, 08:15 | #9 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
12-27-2017, 18:55 | #11 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | check this, unpack and replace original file MTK_AllInOne_DA_SP.bin on C:\InfinityBox\CM2MTK\Boot LINK 1 : https://mega.nz/#F!2IQU1RIJ!8no8PWEwCPHkueCq3WoOtw 1)NEED TO CHANGE DA FILES IN BOOT FOLDER AND SELECT MT6580_Android_scatter.txt FILE IN FLASH TAB 2)VERY IMPORTAINT BEFORE DO ANY OPREATION MAKE READ INFO 3)NEED TO PRESS VOL "+" &"-" TILL THE END OPREATION AND YOU WILL SUCCESS 4)POST LOG OPREATION 5)IF ANY PROBLEM I CAN HELP YOU OK GOOD LUCK |
The Following 15 Users Say Thank You to localizator For This Useful Post: |
01-03-2018, 19:05 | #13 (permalink) |
No Life Poster Join Date: Aug 2016 Location: A few details about yourself Age: 33
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | Any full flash for this phone? I received a dead one because someone tried to remove FRP and flashed wrongly thanks |
03-07-2018, 14:40 | #14 (permalink) | |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Quote:
The Following User Says Thank You to Unlocker AL For This Useful Post: |
05-17-2018, 13:07 | #15 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Romania
Member: 730652 Status: Offline Thanks Meter: 74 | Blackview A7 update My phone name is iHunt Rainbow3 it is a same with blackview a7 works for me with DA_SWSEC.bin !!! |
The Following User Says Thank You to jordachi For This Useful Post: |
