03-11-2016, 13:58 | #1 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2520383 Status: Offline Thanks Meter: 1 | QMobile T2 SPD SC6531 Formet Prob :( i have Qmobile T2 Bold Pattren lock want formet but Allways Stock There any Solotion PLs share with me hare is Logs 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 22 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... |
03-11-2016, 14:11 | #3 (permalink) |
Member: 2520383 Status: Offline Thanks Meter: 1 | 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 22 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable |
03-11-2016, 14:18 | #4 (permalink) |
Member: 2520383 Status: Offline Thanks Meter: 1 | Thanks Done :) 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 22 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
