11-13-2017, 16:01 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: tripoli,libya Age: 36
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | blu old mtk 6260 write flash problem i have BLU Tank II T193 mtk 6261 i want to change language in some new phones come english only and i need arabic when i want to write flash the software hang and there is errors when i read flash plz i need help read info ok Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 887 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 4C7777326749E337FA9A4852443CCBB9 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : DONE NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 [ERROR] : DA_BLANK_FLASH INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : ZECHIN61M_GB_11C_PCB01_gsm_MT6261_S00.BLU_T193_V14_GENERICANATEL.bin FileVersion : BLU_T193_V14_GENERICANATEL Done! Elapsed: 00:00:11 read flash Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 887 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 4C7777326749E337FA9A4852443CCBB9 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : DONE NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 [ERROR] : DA_BLANK_FLASH INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 3145728 bytes read Check and collect compile info File_Info : ZECHIN61M_GB_11C_PCB01_gsm_MT6261_S00.BLU_T193_V14_GENERICANATEL.bin FileVersion : BLU_T193_V14_GENERICANATEL Code : 0x01, error while making FW! Make FlashRead as dump and send to support! Done! Elapsed: 00:00:13 Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 887 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 4C7777326749E337FA9A4852443CCBB9 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : DONE NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 [ERROR] : DA_BLANK_FLASH INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : ZECHIN61D_GB_11C_PCB01_gprs_MT6261_S00.BLU_T193_V02_ARABIC.bin FileVersion : BLU_T193_V02_ARABIC Flash now Erase region , wait ... [ERROR] : DA_INVALID_RANGE Write data , wait ... Write : ZECHIN61D_GB_11C_PCB01_GPRS_MT6261_S00.BLU_T193_V02_ARABIC.BIN |
11-13-2017, 20:24 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | It will not work, because device Flash size just 3 MiB, you trying flash 4MiB file. |
12-03-2017, 14:47 | #5 (permalink) |
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | finally i revive my phone after long time i found the same flash file as you said but no arabic no matter Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 393 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 41A97A9ACB1D96D056594AD537E895AC BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 3145728 bytes read Check and collect compile info File_Info : ZECHIN61M_GB_11C_PCB01_gsm_MT6261_S00.BLU_T193_V14_GENERICANATEL.bin FileVersion : BLU_T193_V14_GENERICANATEL Saved to : C:\InfinityBox\CM2MTK\Read_out\ZECHIN61M_GB_11C_PCB01_gsm_MT6261_S00.BLU_T193_V14_GENERICANATEL.bin Done! Elapsed: 00:00:17 Reconnect Power/Cable! Finish at : [12/3/2017 / 3:36:41 PM] Load File File_Info : ZECHIN61M_GB_11C_PCB01_gsm_MT6261_S00.BLU_T193_V14_GENERICANATEL.bin FileVersion : BLU_T193_V14_GENERICANATEL Load File Ok Start at : [12/3/2017 / 3:37:49 PM] Operation : Flash [ v1.58 ] ======= Flash Files set for flashing : [ MCU ] : ZECHIN61M_GB_11C_PCB01_gsm_MT6261_S00.BLU_T193_V14_GENERICANATEL.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 393 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 4C7777326749E337FA9A4852443CCBB9 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : DONE NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 [ERROR] : DA_BLANK_FLASH INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : ZECHIN61M_GB_11C_PCB01_gsm_MT6261_S00.BLU_T193_V14_GENERICANATEL.bin FileVersion : BLU_T193_V14_GENERICANATEL Flash now Erase region , wait ... Write data , wait ... Write : ZECHIN61M_GB_11C_PCB01_gsm_MT6261_S00.BLU_T193_V14_GENERICANATEL.bin Done! Elapsed: 00:00:50 Reconnect Power/Cable! |
