Blue 651x dead : Infinity team help me ??? I have a Blue 651x which was hanging on Blue startup screen. I flashed with Infinity and now set is totally dead. But still connects to the software. here is the last log :- Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6227:8A02:8A01]... chip: 0031:E289:D82D boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] (or higher) generation security area#1 damaged, recalculation required identification#1 detection finished device-id: 337DF795 identification#1 protocol ver: 04 ver. sw1: MK11_HINDI_PCB01_GPRS_MT6227_S01.V1_00_01_M070309I N0-V21.BIN ver. sw2: V1.00.01_M070309IN0-V21 ffs offset/size: 00E00000/00200000 detecting languages... .................................. language parameters detected detected languages: En Hi reading [eeprom[MK11_HINDI_PCB01_GPRS_MT6227_S01.V1_00_01_M070309I N0-V21.BIN]]... file saved: C:\Documents and Settings\@muskan@\Desktop\MModule\backup_eeprom[MK11_HINDI_PCB01_GPRS_MT6227_S01.V1_00_01_M070309I N0-V21.BIN]_20071205-143049.B0E.bin Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... Area: Firmware flash: 98004900000001:29EA0000000000 Write: Firmware Area: Eeprom flash: 98004900000001:29EA0000000000 Write: Eeprom Write Done Finished, time used: 436 sec Remove/Install battery now ! Plz infinity team help me. And advise what to do next..... |
hello at first are you read this warning in software!! - make full backup before unlock, reset, flash operation due to different hardware configurations exists. second are YOU tryed with format ffs before flashing this phone? |
@zeelzeel run "ChineseMiracle" software and press "Repair security area" button. Let's see results. |
used Chinese Miracle 2.08 but no success. Security area#1 is not being repaired. Any other idea/solution. |
How about to post log here ? Did you opened phone and checked phone hardware ? |
Dear Infinity Support, here is the repair security area with Chinese Miracle 2.11 ..... Action: repair security area Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6227:8A02:8A01]... chip: 0031:E289:D82D boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 damaged, recalculation required identification#1 detection finished device-id: 337DF795 identification#1 protocol ver: 04 ver. sw1: MK11_HINDI_PCB01_GPRS_MT6227_S01.V1_00_01_M070309I N0-V21.BIN ver. sw2: V1.00.01_M070309IN0-V21 ffs offset/size: 00E00000/00200000 flash: 98004900000001:29EA0000000000 flash: 98004900000001:29EA0000000000 Write: security area#1 security area#1 fixed detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished Finished, time used: 24 sec Remove/Install battery now ... -------- Still security area not repaired. Here is the log ..... Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6227:8A02:8A01]... chip: 0031:E289:D82D boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 damaged, recalculation required identification#1 detection finished device-id: 337DF795 identification#1 protocol ver: 04 ver. sw1: MK11_HINDI_PCB01_GPRS_MT6227_S01.V1_00_01_M070309I N0-V21.BIN ver. sw2: V1.00.01_M070309IN0-V21 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000001:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... .................. detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... ............................................ detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok Finished, time used: 38 sec Remove/Install battery now ! need_help..... |
@zeel_zeel I think it may be a phone hardware problem. Please, make this: reball/rehat CPU and flash chip (please, both) and then repeat flash process. Please, do as I suggest, not just say that you have tried but really try it. Right now I don't see any other reason why phone can't be repaired, only hardware is a problem. Please, try as I suggest and lets see results. |
