Old 12-11-2007, 17:49   #1 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,162
Blue 651x dead : Infinity team help me ???
I have a Blue 651x which was hanging on Blue startup screen. I flashed with Infinity and now set is totally dead. But still connects to the software.
here is the last log :-
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6227:8A02:8A01]...
chip: 0031:E28982D
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 98004900000001:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Identification...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] (or higher) generation
security area#1 damaged, recalculation required
identification#1 detection finished
device-id: 337DF795
identification#1 protocol ver: 04
ver. sw1: MK11_HINDI_PCB01_GPRS_MT6227_S01.V1_00_01_M070309I N0-V21.BIN
ver. sw2: V1.00.01_M070309IN0-V21
ffs offset/size: 00E00000/00200000
detecting languages...
language parameters detected
detected languages: En Hi
reading [eeprom[MK11_HINDI_PCB01_GPRS_MT6227_S01.V1_00_01_M070309I N0-V21.BIN]]...
file saved: C:\Documents and Settings\@muskan@\Desktop\MModule\backup_eeprom[MK11_HINDI_PCB01_GPRS_MT6227_S01.V1_00_01_M070309I N0-V21.BIN]_20071205-143049.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
Area: Firmware
Write: Firmware
Area: Eeprom
Write: Eeprom
Write Done
Finished, time used: 436 sec
Remove/Install battery now !
Plz infinity team help me. And advise what to do next.....
Old 12-11-2007, 18:09   #2 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,569
hello
at first are you read this warning in software!!
- make full backup before unlock, reset, flash operation due to different hardware configurations exists.
second are YOU tryed with format ffs before flashing this phone?
Old 12-12-2007, 07:50   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
@zeelzeel
run "ChineseMiracle" software and press "Repair security area" button.
Let's see results.
Old 12-12-2007, 12:26   #4 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,162
used Chinese Miracle 2.08 but no success. Security area#1 is not being repaired. Any other idea/solution.
Old 12-12-2007, 12:36   #5 (permalink)
Member: 130995
How about to post log here ?
Did you opened phone and checked phone hardware ?
Old 12-19-2007, 17:16   #6 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,162
Dear Infinity Support, here is the repair security area with Chinese Miracle 2.11 .....
Action: repair security area
Boot...
19200
Connecting, wait...
chip: 0031:E28982D
Boot Done
Initialize...
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
identification#1 structure: 2nd [enhanced] generation
device-id: 337DF795
Write: security area#1
security area#1 fixed
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
Finished, time used: 24 sec
Remove/Install battery now ...
Still security area not repaired. Here is the log .....
Action: read/check detailed information
Boot...
19200
Connecting, wait...
chip: 0031:E28982D
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Identification...
device-id: 337DF795
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
Finished, time used: 38 sec
need_help.....
Old 12-19-2007, 22:12   #7 (permalink)
Member: 130995
@zeel_zeel
I think it may be a phone hardware problem.
Please, make this: reball/rehat CPU and flash chip (please, both) and then repeat flash process.
Please, do as I suggest, not just say that you have tried but really try it. Right now I don't see any other reason why phone can't be repaired, only hardware is a problem. Please, try as I suggest and lets see results.
Infinity can't unlock MXNEC N9 chip Infineon 7880, Infinity team help me ! coolderheart Infinity-Box 1 11-15-2009 06:12
infinity team help me pls serakyol Infinity-Box 5 02-07-2008 07:30
infinity team help me please! lmt Infinity-Box 1 02-02-2008 18:02
infinity team help me jmustufa Infinity-Box 0 04-07-2007 05:26
infinity team help me jmustufa Infinity-Box 1 03-21-2007 11:20
Page generated in 0.23141 seconds with 10 queries
