bluetooth 999 needed pin out hello team any have pin out blue tooth 999 thank you |
hello infinity team need pin out |
infinity box i need your help |
hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software If it does supported, and you dont have infinity Pinfinder- i can teach how to find pinout in minutes. Just by measuring voltage on phone system connector pins. |
what is this it is supported for infinity .the phone is hung up if you fresh the power on the phone is blinking . http://i833.photobucket.com/albums/z...ntitled-18.jpg |
i need flash file bluetooth 999 no file in support ffs thank you |
COM10 [VCP0] selected module v2.84 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 4 sec Remove/Install battery now ! |
hello! you are using wrong pinout and very old Chinese Miracle module |
