GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   Bluetooth a968 pinout, urgent (https://forum.gsmhosting.com/vbb/f296/bluetooth-a968-pinout-urgent-546436/)
josephic 06-03-2008 13:14
Bluetooth A968
I found the pinouts for the first cpu using infinity box and pinfinder
connector 1x18 (L18B)
cpu 1
CPU: MT6225
result: Rx:12 Tx:10
but I can't find pinouts for cpu 2
please help urgently
thanks in advance
mentari 06-03-2008 13:45
Originally Posted by josephic (Post 3368356)
Bluetooth A968
cpu 1
CPU: MT6225
result: Rx:12 Tx:10
thanks in advance
for cpu 2 maybe on pcb, or it got diffrent power on button, just open your phone and see if got rx_b tx_b or rx_2 tx_2 word
or power on b
josephic 06-03-2008 18:03
no pinouts on the pcb except the power-a and power-b pins, I have already opened the phone and looked for those pins but nothing found. the only way is to find the pinouts by pinfinder or soldering the cables to the point where the socket connected to the pcb. but also I can't find to which legs to solder
InfinityHelp 06-03-2008 19:55
hello!
can you measure voltages on all phone pins?
Mansoor 06-04-2008 07:53
Or
Originally Posted by InfinityHelp (Post 3369297)
hello!
Or please can you tell us more about mesuring the pinout and after that what next please
InfinityHelp 06-04-2008 09:45
hello!
very easy.
take multimeter, one probe to some grounded phone part.
by another probe you touch one by one all phone pins.
Ignore pins for CPU1
CPU2 pins will have voltage 2,7-2,9 volts
some phones require both SIM to be inserted in phone in order to be found
mentari 06-05-2008 19:48
i just want to help.
may be you can use this way.
put your simcard,
press find it on your infinity finder, a information windows will appear, after that, connect power_on_b to gnd and hold it, press ok on information window.
josephic 06-08-2008 17:51
first: I thank you too much for your interest my friends, I appreciate this.
correction: the connector was 1x20 but this is not the matter, after I tried it with 1x18 immediately changed to 1x20.
using 1x18 cpu 1 pinouts are rx=12 tx=10,
using 1x20 rx=13 tx=11
anyway....
I tried all these things you are talking about. there is no power_a or power_b pins on the pcb. no rx tx pinouts on the pcb. (or I couldn't see them, and this is very little possibility). I think we aggree on that we are here to find solutions and help each other.
frankly infinity box doesn't cost that much money or the team must provide a wide database about phone and support more models.
it doesn't seem to happen.
again anyway.
after 20 days I'll have more time for these things. and now inviting you establish a team to build the needed database and publish it on the internet for members.
InfinityHelp 06-08-2008 20:21
hello mr.josephic!
if i could get this phone to my own hands i would find pinout in minutes.
but problem is that some models is very rare.
so for this models is easyer to find pinout by yourself instead of waiting 20 days
take multimeter and measure voltages on all phone pins
detect pinout_2 by voltages 2,7-2,9volts
MOBILECHANNEL 01-27-2009 10:00
Need a968 pin out
I HAVE A968 15 PCS FOR RESTART PROBLEM I MAKE IT FROM SOFTWARE I NEED ITS RX TX PLE HELP ME SOME ONE CABLE PINS 1X20
[email protected]
InfinityHelp 01-27-2009 20:54
[email protected]
hello!
1. set multimeter to voltage measuring.
2. check bettery voltage, it should be more than 3,7volts
3. set one multimeter probe to some grounded phone part
(if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal)
4. with second probe touch one by one all phone pins (phone battery attached)
(to get better result i would advice to set needle on the end of second probe)
memorise pins with voltage between 2,7-2,9volts.
those are tx/rx
ahamed imran 10-23-2009 15:29
anyway....
again anyway.
1*20 tx- rx 100% working i tested thank you my friend
SanjeewaG 12-23-2010 14:11
A968 Pinouts Tx Rx
1 Attachment(s)
Thanks Infinity Team!
COM16 [VCP0] selected
module v3.25
Action: read unlock codes
unlock method: read codes
Model: Autodetect 6205-6239 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:9C03:0003
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: E890_EVSMT3B.01.1
Version: EVEN6225_GEMINI_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35968980974629
connection Ok
detecting structure #1...
1 2 5 8 9 10 12 13 14 done
178 byte(s) read
166 byte(s) read
Phone lock: On
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 429264
Finished, time used: 11 sec
Remove/Install battery now !
Originally Posted by InfinityHelp (Post 3370644)
hello!
very easy.
Page generated in 0.61695 seconds with 6 queries
