Old 06-03-2008, 13:14   #1 (permalink)
Member: 761539
Thanks Meter: 2
Bluetooth a968 pinout, urgent
Bluetooth A968
I found the pinouts for the first cpu using infinity box and pinfinder
connector 1x18 (L18B)
cpu 1
CPU: MT6225
result: Rx:12 Tx:10
but I can't find pinouts for cpu 2
please help urgently
thanks in advance
Old 06-03-2008, 13:45   #2 (permalink)
Member: 39948
Thanks Meter: 68
Originally Posted by josephic View Post
Bluetooth A968
cpu 1
CPU: MT6225
result: Rx:12 Tx:10
thanks in advance
for cpu 2 maybe on pcb, or it got diffrent power on button, just open your phone and see if got rx_b tx_b or rx_2 tx_2 word
or power on b
Old 06-03-2008, 18:03   #3 (permalink)
Member: 761539
Thanks Meter: 2
no pinouts on the pcb except the power-a and power-b pins, I have already opened the phone and looked for those pins but nothing found. the only way is to find the pinouts by pinfinder or soldering the cables to the point where the socket connected to the pcb. but also I can't find to which legs to solder
Old 06-03-2008, 19:55   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
can you measure voltages on all phone pins?
Old 06-04-2008, 07:53   #5 (permalink)
Mansoor's Avatar
Member: 45561
Thanks Meter: 59
Or
hello!
Or please can you tell us more about mesuring the pinout and after that what next please
Old 06-04-2008, 09:45   #6 (permalink)
Member: 148515
hello!
very easy.
take multimeter, one probe to some grounded phone part.
by another probe you touch one by one all phone pins.
Ignore pins for CPU1
CPU2 pins will have voltage 2,7-2,9 volts
some phones require both SIM to be inserted in phone in order to be found
Old 06-05-2008, 19:48   #7 (permalink)
Member: 39948
Thanks Meter: 68
i just want to help.
may be you can use this way.
put your simcard,
press find it on your infinity finder, a information windows will appear, after that, connect power_on_b to gnd and hold it, press ok on information window.
Old 06-08-2008, 17:51   #8 (permalink)
Member: 761539
Thanks Meter: 2
first: I thank you too much for your interest my friends, I appreciate this.
correction: the connector was 1x20 but this is not the matter, after I tried it with 1x18 immediately changed to 1x20.
using 1x18 cpu 1 pinouts are rx=12 tx=10,
using 1x20 rx=13 tx=11
anyway....
I tried all these things you are talking about. there is no power_a or power_b pins on the pcb. no rx tx pinouts on the pcb. (or I couldn't see them, and this is very little possibility). I think we aggree on that we are here to find solutions and help each other.
frankly infinity box doesn't cost that much money or the team must provide a wide database about phone and support more models.
it doesn't seem to happen.
again anyway.
after 20 days I'll have more time for these things. and now inviting you establish a team to build the needed database and publish it on the internet for members.
The Following 2 Users Say Thank You to josephic For This Useful Post:
Old 06-08-2008, 20:21   #9 (permalink)
Member: 148515
hello mr.josephic!
if i could get this phone to my own hands i would find pinout in minutes.
but problem is that some models is very rare.
so for this models is easyer to find pinout by yourself instead of waiting 20 days
take multimeter and measure voltages on all phone pins
detect pinout_2 by voltages 2,7-2,9volts
Old 01-27-2009, 10:00   #10 (permalink)
MOBILECHANNEL's Avatar
Member: 746449
Sonork: 100.1603972
Thanks Meter: 171
Need a968 pin out
I HAVE A968 15 PCS FOR RESTART PROBLEM I MAKE IT FROM SOFTWARE I NEED ITS RX TX PLE HELP ME SOME ONE CABLE PINS 1X20
[email protected]
Old 01-27-2009, 20:54   #11 (permalink)
Member: 148515
[email protected]
hello!
1. set multimeter to voltage measuring.
2. check bettery voltage, it should be more than 3,7volts
3. set one multimeter probe to some grounded phone part
(if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal)
4. with second probe touch one by one all phone pins (phone battery attached)
(to get better result i would advice to set needle on the end of second probe)
memorise pins with voltage between 2,7-2,9volts.
those are tx/rx
Old 10-23-2009, 15:29   #12 (permalink)
Member: 199202
Thanks Meter: 37
anyway....
again anyway.
1*20 tx- rx 100% working i tested thank you my friend
Old 12-23-2010, 14:11   #13 (permalink)
Member: 366714
Thanks Meter: 21
A968 Pinouts Tx Rx
Thanks Infinity Team!
COM16 [VCP0] selected
module v3.25
Action: read unlock codes
unlock method: read codes
Model: Autodetect 6205-6239 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:9C03:0003
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: E890_EVSMT3B.01.1
Version: EVEN6225_GEMINI_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35968980974629
connection Ok
detecting structure #1...
1 2 5 8 9 10 12 13 14 done
178 byte(s) read
166 byte(s) read
Phone lock: On
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 429264
Finished, time used: 11 sec
Remove/Install battery now !
hello!
very easy.
The Following User Says Thank You to SanjeewaG For This Useful Post:
A968 pinouts ramteja Chinese Models & Cloned Phones 2 01-08-2011 13:23
need a968 pinout shsampath Chinese Models & Cloned Phones 2 07-02-2010 01:26
6275 set bluetooth not open urgent guddu20690 Nokia CDMA 2 05-15-2009 05:19
Sony-erisson Chang Jiang A968 pinout Fernandowap Chinese Cocktail 1 11-08-2008 23:12
China Model V12 Bluetooth Flash file urgently needed zubairok Infinity-Box 23 11-04-2008 12:14
Page generated in 0.28117 seconds with 10 queries
