12-08-2007, 19:26 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Due to a lot of different models with the same name but absolutely different hardware (f.e. exist at least 5 phones with name "Chinese Nokia-N95" but different pinouts), bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
12-08-2007, 20:05 | #3 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | give full details about your phone. what connector does your phone have? there are lots of things to check b4 asking for help (it will save your time). did u open the phone? (sometimes the Tx Rx are marked on the phone's PCB) BR Mansi |
12-09-2007, 08:44 | #4 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | Quote:
phone connector is 2x6 same as Chinese Nokia N95 | |
12-18-2007, 08:47 | #8 (permalink) | |
Hello, You can try to find pinout by yourself, I have an instruction how to do it: Due to a lot of different models with the same name but absolutely different hardware (f.e. exist at least 5 phones with name "Chinese Nokia-N95" but different pinouts), bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 | |
Need n79 pinouts | joe cellular | Nokia Base Band 5 ( BB-5 ) | 2 | 02-25-2010 20:14 |
nokia n79 pinout need | gsm5378 | GPS devices , Navigators & Maps | 1 | 03-29-2009 21:40 |
please china n79 pinout????? | amirhossein kt | SpiderMan | 2 | 02-22-2009 22:53 |
tried three days for n79 PINOUT-can not help | zonetrichur | Infinity-Box | 1 | 12-26-2007 07:01 |
need chinese n79 pinout | shahzad-0004 | Infinity-Box | 1 | 06-11-2007 04:09 |
