10-17-2014, 21:55 | #1 (permalink) |
Product Supporter Join Date: Mar 2005 Location: in CPU
Member: 128745 Status: Offline Thanks Meter: 16,936 | Unlock Samsung Note 4, ALPHA AND G800 with DT Samsung Client BATTERY TRICK TO UNLOCK G800 BELOW BATTERY TRICK TO UNLOCK NOTE 4 AND ALPHA BELOW |
The Following 10 Users Say Thank You to Infinity-Box For This Useful Post: |
11-24-2014, 09:21 | #3 (permalink) |
Freak Poster Join Date: Jan 2009 Location: india,kerala..in NAJMU
Member: 955971 Status: Offline Sonork: 100.1638835 Thanks Meter: 115 | G530H Successfully Unlock Via This Method.....Congrates Team...... Model: SM-G530H HWID: CQN00E78EC29391 Imei: 357213xxxxxxxx Starting unlock process. Msladdress READED OK. Sending data to server. Sending Authorization to the phone. Phone authorized OK. Checking status of simlock. Simlock status: 00004000 Unlock Done. If phone ask for code, enter 00000000. Restarting phone. |
The Following User Says Thank You to simcityreal For This Useful Post: |
11-24-2014, 11:17 | #4 (permalink) | |
Member: 128745 Status: Offline Thanks Meter: 16,936 | Quote:
wich method did u try the G800 or Alpha ? | |
11-26-2014, 14:00 | #6 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Chittagong, Bangladesh.
Member: 152752 Status: Offline Sonork: 100.1581661 Thanks Meter: 182 | After using then method then working well Model: SM-G530H HWID: CQN00CB56C22991 Imei: 357213060 Starting unlock process. Msladdress READED OK. Sending data to server. Sending Authorization to the phone. Phone authorized OK. Checking status of simlock. Simlock status: 00004000 Unlock Done. If phone ask for code, enter 00000000. Restarting phone. BR |
11-29-2014, 12:21 | #8 (permalink) |
No Life Poster Join Date: May 2008 Location: Bangladesh
Member: 782943 Status: Offline Sonork: 100.1601067 Thanks Meter: 204 | Model: SM-G530H HWID: CQN00E757C28991 Imei: 357213******** Starting unlock process. Msladdress READED OK. Sending data to server. Sending Authorization to the phone. Phone authorized OK. Checking status of simlock. Simlock status: 00004000 Unlock Done. If phone ask for code, enter 00000000. Restarting phone. Sucesfully unlock with Alpha battery trick |
The Following User Says Thank You to raselcox For This Useful Post: |
12-15-2014, 17:33 | #15 (permalink) |
No Life Poster Join Date: Jan 2013 Location: HUAWEI FRP KEY imei-code
Member: 1870489 Status: Offline Sonork: 100.1663831 Thanks Meter: 483 | SM-G530H unlock done Model: SM-G530H HWID: CQN00F607EE49A1 Imei: 35721306205828 Starting unlock process. Msladdress READED OK. Sending data to server. Sending Authorization to the phone. Phone authorized OK. Checking status of simlock. Simlock status: 00000000 Unlock Done. If phone ask for code, enter 00000000. Restarting phone. |
