Old 12-02-2008, 15:55   #1 (permalink)
Member: 377736
...:Bolo C68 successfully unlocked:...
cpu: Infineon
Just select c62
Logs:
COM6 [VCP0] selected
module v1.57
Device: Bolo-C62
Checking data, wait...
Action: unlock
Boot ...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Bolo-C62_eeprom-static_20081202-231743.B1E.bin
loading data...
wrong database file: C:\Program Files\InfinityBox\Pana01\ulc1_i100_eep65535.cfg
error: can't load database v.8
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Bolo-C62_eeprom-security_20081202-231745.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Bolo-C62_eeprom-complete_20081202-231800.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
Erasing: eeprom-complete
Writing: eeprom-complete
Write Done
Finished, time used: 44 sec
Remove/Install battery now !
" Knowledge is the beginning of wisdom"
The Following User Says Thank You to jamdy For This Useful Post:
Old 12-02-2008, 16:46   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Hello,
Thanks for information !
What cable you have used ?
5230 boot display SIM card invalid ATF success with good repair! 20442044 Advance-Box 1 03-30-2010 03:08
samsung t639 no signal after unlocked: ps_tech NSPRO 0 07-23-2009 13:38
Bolo C68 Unlocked Done.... dyowei Infinity-Box 2 02-18-2009 17:36
Iphone unlocked: Should i register at itunes or not? gsmforum2008 iPhone ,iPod & iPad (Apple Inc. Products) 2 04-30-2008 16:55
Page generated in 0.20362 seconds with 11 queries
