Old 09-28-2007, 15:44   #1 (permalink)
Member: 160111
Thanks Meter: 10
N95 flashed ok but cant do pen cailbration
hello friends
i had to flash my N95 (chineese miracle) up to ten times with different files, at last i got one file that made it work, ask file made and converted to rpl and writen in phone all ok, but i cant use the stick or pen on the LCD.
IS THERE ANY KNOWN SOLUTION TO THIS HEADACE?
Old 09-28-2007, 15:58   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Probably you need to use other flash file, it may be that your phone hardware not compatible with current firmware.
Old 09-29-2007, 07:51   #3 (permalink)
Member: 160111
Thanks Meter: 10
thanks for the option given, but i have used almost all the files available. so i should keep trying?
Old 09-29-2007, 12:16   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
if you dont know/dont have original version of your phone- then yes, you must ry them all
Old 09-29-2007, 13:07   #5 (permalink)
virgin_phones's Avatar
Member: 359939
Sonork: none
Thanks Meter: 61
i also have the same problem but my case screen is white screen. i tried all files names with pda because my phone is n95 pda. or should i try other files which are not for pda?
Old 09-29-2007, 14:59   #6 (permalink)
Member: 130995
Yes, you can try to use other files. Main thing is firmware version name but not phone name, so find files with similar firmware version and flash it (model name is not so important)
Network ok but cant do any call after unlock. mamepap iPhone 2 / iPhone 3G / iPhone 3GS 7 08-30-2009 10:09
2310 flash ok but cant power on Jayrus Nokia Hardware & Hardware Repair 3 01-13-2008 16:48
N95 flash ok but black screnn , test mode and local mode can't be done ali_alper Nokia Base Band 5 ( BB-5 ) 0 05-28-2007 13:59
N91 flash ok.but cant do ui setings uacharitha20 Nokia Hardware & Hardware Repair 3 04-13-2007 20:14
8310 dead flashing ok but cant power on mobilemafia Nokia Hardware & Hardware Repair 13 06-11-2003 23:00
Page generated in 0.15409 seconds with 9 queries
