Old 09-28-2007, 15:52   #1 (permalink)
jothi737's Avatar
Member: 369539
Sonork: 1584109
Thanks Meter: 32
boot error??????????????????????help infinity
zt588 1x20 pin
COM3 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection active
Action: reset
Boot...
baud autodetection active
19200
Connecting, wait...
error: boot phase#1 failed
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect" box.
Boot Fail
Finished, time used: 5 sec
Remove/Install battery now !
what problem
i change cable but same pls help
Old 09-28-2007, 16:01   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
It's cable problem, wrong pinout. You must use correct cable and select correct COM port.
Due to a lot of different models with the same name but absolutely different hardware,
bottom connectors and different pinouts we recommend you to make detailed description of model,
attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector.
After you have this information prepared, please, check the next detailed description how to get pinout for your model:
use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt
if not helps, please read: http:///vbb/showpo...36&postcount=7
if not helps, please read: http:///vbb/showthread.php?t=433447
Old 09-28-2007, 20:48   #3 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
Thanks Meter: 4,267
MAN can u tell what models of infinity box do you use???
please put a picture of it here..
is it the new small box ?????????
or the old big one??
Old 09-29-2007, 13:54   #4 (permalink)
Member: 130995
There is absolutely no any difference what box to use: old, new, not so new, not so old, red, silver, black, blue or any other color or size.
Old 09-29-2007, 14:59   #5 (permalink)
muhned's Avatar
Member: 201469
Sonork: software
Thanks Meter: 50
hi
i have same problem
i have infinity red box and i have cable the infinity for chinese miracle ( 29 cable infinity for chinese miracle )
but not connect the infinity with any model
Exa cable anycool d66 i use cable name ( UB - CECT004 CECT U8800 )
help infinity team
Nokia N72 Booting error help JOCKER102 Nokia Base Band 5 ( BB-5 ) 2 11-29-2009 18:13
N73 ape boot error help odraregnivla Nokia Base Band 5 ( BB-5 ) 5 03-06-2009 16:19
c92 boot error, infinity help ? aloksoni Infinity-Box 18 02-24-2008 09:48
6600 2nd boot error help me babatnagar Nokia Hardware & Hardware Repair 9 08-22-2007 19:00
6310i and 7110 ! 1st Boot Error! Help Maurone Twisterflasher 9 06-11-2005 02:23
Page generated in 0.19217 seconds with 9 queries
