09-28-2007, 15:52 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: INDIA TAMILNADU SALEM
Member: 369539 Status: Offline Sonork: 1584109 Thanks Meter: 32 | boot error??????????????????????help infinity COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 5 sec Remove/Install battery now ! what problem i change cable but same pls help |
09-28-2007, 16:01 | #2 (permalink) |
Product Manager Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks Meter: 35,227 | It's cable problem, wrong pinout. You must use correct cable and select correct COM port. Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
09-28-2007, 20:48 | #3 (permalink) |
No Life Poster Join Date: Jul 2005 Location: France Age: 48
Member: 165812 Status: Offline Sonork: 100:1627635 Thanks Meter: 4,267 | MAN can u tell what models of infinity box do you use??? please put a picture of it here.. is it the new small box ????????? or the old big one?? |
09-29-2007, 14:59 | #5 (permalink) |
No Life Poster Join Date: Nov 2005 Location: EingneeR
Member: 201469 Status: Offline Sonork: software Thanks Meter: 50 | hi i have same problem i have infinity red box and i have cable the infinity for chinese miracle ( 29 cable infinity for chinese miracle ) but not connect the infinity with any model Exa cable anycool d66 i use cable name ( UB - CECT004 CECT U8800 ) help infinity team |
Nokia N72 Booting error help | JOCKER102 | Nokia Base Band 5 ( BB-5 ) | 2 | 11-29-2009 18:13 |
N73 ape boot error help | odraregnivla | Nokia Base Band 5 ( BB-5 ) | 5 | 03-06-2009 16:19 |
c92 boot error, infinity help ? | aloksoni | Infinity-Box | 18 | 02-24-2008 09:48 |
6600 2nd boot error help me | babatnagar | Nokia Hardware & Hardware Repair | 9 | 08-22-2007 19:00 |
6310i and 7110 ! 1st Boot Error! Help | Maurone | Twisterflasher | 9 | 06-11-2005 02:23 |
