12-10-2009, 11:20 | #1 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 474339 Status: Offline Thanks Meter: 44 | vodafone 541 flashing with infinity but no network i wrote eeprom from support and flash but no network then i wrote working fone eeprom and flash from support but still same here is the log COM5 [VCP0] selected module v2.97 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:0503:A008 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.BDD16 7CC.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_A8667CC5].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: BDD167CC rom info protocol ver: 07 ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN ver. sw 2: MAUI.08A.W08.40.SP1.V32, C57C66A8 address offset: 00020000 ffs offset/size: 01800000/00800000 TCL-ID identification version: 16G provider: 708A-2CTLGT3 customization: CN16NT24 customization: XN16NT24 TCL-ID identification done ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN16NE21 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN16NE21 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_BDD167CC_A8667CC5_20091210-101128.B0X.bin Finished, time used: 342 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! then i unlocked...but no success.. plz help |
12-10-2009, 14:36 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | what was the condition of mobile ? and why you flash the mobile ? is it dead , its yes then how its become dead , maybe its hardware problem Br Faisal_Computer |
12-11-2009, 11:12 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You can try to flash phone with different flash files from support area and see results, but if phone can not make 112/emergency call - it's hardware problem in most cases. |
12-13-2009, 08:33 | #9 (permalink) | |
Member: 151871 Status: Offline Thanks Meter: 71,421 | Quote:
BR Faisal_Computer | |
The Following User Says Thank You to Faisal_Computer For This Useful Post: |
LG KG130 unlock with hwk but no network | denard | HWK | 1 | 06-04-2013 11:47 |
help vodafone 332fm flash with infinity | godwin | Infinity-Box | 2 | 03-26-2010 18:41 |
Vodafone 541, flashed with 708a [CLOSED] | hugmax | PolarBox 3 | 6 | 12-28-2009 22:12 |
Successfully unlock and flash ALCATEL C701X But no network | khawar | Infinity-Box | 9 | 12-12-2009 11:49 |
Kg195 Flash With Infinity But.........help | sairat | Infinity-Box | 10 | 02-04-2008 18:48 |
