06-12-2007, 23:16 | #1 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 199538 Status: Offline Thanks Meter: 54 | Boot Fail when i try to flash a panasonic GD55 !!! When i try to flash with a MAIN and a MAP file next error appears .. any help żżż COM1 selected Device: Panasonic-GD55 Checking data, wait... Action: Flash write "smart write" enabled Write: Firmware Write: Map/Customization Skip: Language Pack Skip: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Err: wrong answer, error#01 Boot Fail Err: Finished Remove/Install battery now ! Time used: 86 sec |
06-12-2007, 23:43 | #3 (permalink) |
Member: 199538 Status: Offline Thanks Meter: 54 | NOt support !! i use the special Cable For GD55 like you have in pinout support.. all the conection is OK,,, verify this post all the process conection .. when i try to flash or unlock ,, the same problem.. I think is a eprom problem,, i don´´t find any eprom in support area can you help me to restore this phone .. thanks |
06-13-2007, 09:28 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i dont see in your log normal connection. it fails on early beginning. Most common is cable problem. try to change Rx/tx if it is own made cable |
when i use 5800 cable to unlocl it works but when i try to flash it it dosnt work why | observer123 | Universalbox | 2 | 07-25-2009 16:48 |
Big problem when i try to flash 6020 !! | dynamic-gsm | Nokia Digital Core Technology 4 ( DCT-4 ) | 8 | 03-27-2009 03:13 |
When I try to flash x680v it says:Error loading flash loader | beneto | UST Pro II | 2 | 09-19-2008 14:20 |
Error when i try to flash G50 With G50RusTool | flechazo | Panasonic | 0 | 03-23-2005 12:28 |
