Old 06-22-2016, 01:33   #1 (permalink)
Member: 217891
Thanks Meter: 237
i have error with gtide v7
==== Wait for phone...
Phone found! [ 322 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Unknown structure detected! Check correct model selection!
Elapsed: 00:00:18
Reconnect Power/Cable!
Old 06-22-2016, 08:55   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Check Alternative LDR Mode option or use sldr files.
Also there are two options for SC7731- Generic and A5 try with both.
For more refer Manual from support area.
Br.
Infinity Box Support Team.
Old 06-22-2016, 19:06   #3 (permalink)
Member: 217891
Thanks Meter: 237
i do wat u say but same and i try flash and same look here
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x17 records
PMTManager : PMT Update Failed!!!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
[FlashProc] : Error with code 0x038A
Elapsed: 00:00:00
Old 06-23-2016, 08:31   #4 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Charge battery first.
Br.
Old 06-23-2016, 12:15   #5 (permalink)
Member: 217891
Thanks Meter: 237
i charge and i test with power supply and same and when read flash same error
Old 06-24-2016, 17:17   #6 (permalink)
Member: 217891
Thanks Meter: 237
its other g-tide v7 phone look when read info and same error for other phone
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Elapsed: 00:00:17
Old 06-24-2016, 18:01   #7 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
If it already dead it can be normal. Need find correct FW or select correct mode.
Open and read manual first.
Page generated in 0.18642 seconds with 8 queries
