12-28-2008, 07:10 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: CellcomEngineering Age: 42
Member: 147116 Status: Offline Sonork: 100.1578260 Thanks Meter: 316 | BOX problem and RX TX light all the time on. if i connect usb cable RX TX light on. help he Infinity team. |
12-28-2008, 20:03 | #6 (permalink) |
Member: 147116 Status: Offline Sonork: 100.1578260 Thanks Meter: 316 | before 2 days its ok for work. i flash one W220 moto phone. but today i cant work. becouse RJ54 TX RX light always on. today i connect this box for same w220 hang. but TX RX light on and did not find infinity port. com1 com2 other port but VPC0 port cant find and box did not want that driver also.. device maneger did not say driver not found, wrong driver, other msg. what can i do.... but i can go to support with this box.... |
12-29-2008, 11:07 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It may be that FTDI chip in box become damaged (in most cases it's a result of wrong wires connection from box to phone). You can replace box FT232 chip, make search in this forum regarding "FT232" and you will see and instruction. |
12-31-2008, 18:08 | #10 (permalink) | |
Member: 147116 Status: Offline Sonork: 100.1578260 Thanks Meter: 316 | Quote:
like ufs box ftdi ic.......... need any programming on changing ftdi ic.... | |
12-31-2008, 18:17 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, yes, you can take FTDI IC from other box, but check that all letters of FTDI chip is the same due to different types of FTDI chip exist. You do not need to make any programming after FTDI chip replacement. |
12-31-2008, 19:54 | #12 (permalink) | |
good customer support infinity team........... rhanks again........ | |
Spt Box problem! New box dont open the soft [SOLVED] | 69eyes | SPT BOX | 2 | 10-22-2009 12:14 |
Please help... box problem ==> Problem Solve, Not BOX Problem!! Phone pin in PCB! | IR-GSM | PadFinder box | 2 | 09-22-2008 20:46 |
box problem and t609 problem help pls | everblue | UST Pro II | 7 | 08-06-2007 08:20 |
