01-04-2008, 09:57 | #1 (permalink) |
No Life Poster Join Date: May 2001
Member: 4675 Status: Offline Thanks Meter: 7 | box problem - can't connect any phone with usb |
01-04-2008, 11:33 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, You can use any cable and any COM port to work with any phone. Box problem: hard to say what can be wrong. If you have tried to find pinout for Chinese phones before it may be that wires was cinnected to wrong test points and box become damaged and in this case you need to replace FT232 box chip. It's just an idea because some people reportad about damaged boxes after wrong "+" and "-" wires connection. |
01-04-2008, 16:11 | #4 (permalink) |
Member: 4675 Status: Offline Thanks Meter: 7 | ok, is the FT232 chip easily available? or should i send my box to my reseller? maybe it is the reason, because it is working fine before i use my newly bought china cable set, if FT232 is damaged does it mean that i can't also use the COM port of the infinity box? |
01-04-2008, 17:35 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, You have no reason to send box to reseller. If box was damaged during wrong cables useage it's not a warranty situation. FT232 chip available everywhere, f.e. here: http://www.ftdichip.com/ If FT232 chip damaged you still can use box as a dongle (with smart-card inside) but can't use it as usb-rs232 converter and COM port connection via box will be unavailable. |
Can't flash any phones with usb | amil0003 | J.A.F. By Jafsupport.com | 6 | 11-04-2008 10:33 |
I Can't Connect Any Phone To Ustii Help... | DESBLOKING | UST Pro II | 0 | 04-13-2007 15:04 |
