12-21-2009, 13:47 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: WITH BEST NOKIA TOOLS
Member: 492800 Status: Offline Sonork: 100.1601366 Thanks Meter: 1,311 | pls help me.... i need this firmware i need this firmware mobile 6300i HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B _W09_08_MP_V2.BIN project-id: MAUI.08B.W09.08.MP.V2, 00000000 this mobile problem auto shutdown then i flash this 2 version ...but my mobile totally dead..... HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B _W09_08_MP_V2_0625_16m_En_Ru_Fr_Es_It_Tr_Farsi_Pt_ Ar.B0M.bin HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B _W09_08_MP_V2__6300i_16m_En_Ru_Fr_Tr_Farsi_Pt_Ar.B 0M.bin |
12-22-2009, 01:09 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! try also this one: flashfiles/ChineseMiracle/_MT6226/HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B _W09_08_MP_V2_16m_En_Ru_Fr_Tr_Pt_Ar.B0M.bin make format FFS complete after that (if needed). this will rebuild EEPROM to factory state. |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
12-22-2009, 06:16 | #3 (permalink) | |
Member: 492800 Status: Offline Sonork: 100.1601366 Thanks Meter: 1,311 | Quote:
many thanks for ur information ....... i flash with this version but.... display is white n on off tone is ok.. any solution for this problem??? | |
12-22-2009, 08:58 | #5 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | Try with this 16MB .BIN file. @InfinitySupport Convert it to infinity supported format. http://www.4shared.com/file/17859068...INI_PCB01.html BEST OF LUCK! yawarniazi |
12-22-2009, 19:41 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! try converted file and post result here. if this will will solve problem- i will upload it to support too http://rapidshare.com/files/32448536...N.B0M.bin.html |
12-23-2009, 07:51 | #7 (permalink) | |
==== log: [23-Dec-09 1:27:16 PM] ==== COM4 [VCP1] selected module v3.03 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: erase whole flash chip Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:55F8:C4C1 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22022201:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:0035E800000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:0035E800000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #04 in region #00... flash: 01227E22022201:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #05 in region #00... flash: 01227E22022201:0035E800000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #06 in region #00... flash: 01227E22022201:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #07 in region #00... flash: 01227E22022201:0035E800000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22022201:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:0035E800000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 02/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B _W09_08_MP_V2.BIN project-id: MAUI.08B.W09.08.MP.V2, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 2 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 01 ffs/eeprom area: 00800000:00600000-007FFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E22022201:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... chip formatting... flash: 01227E22022201:2AEA0000000000 Erase: chip 1 of 2 flash: 01227E22022201:0035E800000000 Erase: chip 2 of 2 Finalization Done Finished, time used: 2 min 45 sec Remove/Install battery now ! Loading file v.05... HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B _W09_08_MP_V2.BIN.B0M.bin loaded usb bootloader (file) is absent rom info ver: 05 sw version: HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B _W09_08_MP_V2.BIN project-id: MAUI.08B.W09.08.MP.V2, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent ==== log: [23-Dec-09 1:31:23 PM] ==== COM4 [VCP1] selected module v3.03 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B _W09_08_MP_V2.BIN.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:55F8:C4C1 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #04 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #05 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #06 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #07 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning ffs/eeprom address can not be detected, value from database assigned: 00000000/00000000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 01227E22022201:FFFFFF00000000 Write: Firmware jump to next chip: 01 flash: 01227E22022201:FFFFFF00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 10 min 44 sec Remove/Install battery now ! | |
10-24-2010, 07:56 | #9 (permalink) |
Freak Poster Join Date: May 2010 Location: Tebing Tinggi
Member: 1306699 Status: Offline Sonork: GC Thanks Meter: 21 | always error and stop in hafl process when download from support HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B _W09_08_19__ZR-M66_16m_En_Ru_Fr_Es_It_De_Ml_Id_Tr_Farsi_Pt_Ar.B0M .bin |
pls help me.... i need this firmware | jonymahmud | Infinity-Box | 1 | 12-21-2009 18:57 |
Pls help me to check this file and | rolko_mobile | Cyclonebox | 1 | 04-23-2009 19:56 |
Pls help me anyone has this software | iiiaudiologicii | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 04-23-2009 10:20 |
any one can u pls help me out of this w550??? | i_am_rocky | Cruiser Suite | 3 | 02-24-2006 16:18 |
Pls help me to accomplish this stuff !!! | cupmagic | Sim Cloning and Scaning | 6 | 08-19-2005 18:56 |
