02-02-2011, 14:01 | #1 (permalink) |
No Life Poster Join Date: Mar 2009 Location: SYLHET BANGLADESH B.B Age: 40
Member: 997268 Status: Offline Sonork: 100.1661167 Thanks Meter: 113 | help me vodafone 340 after unlock dead try format nothing please help log here COM6 [VCP0] selected module v3.62 Device: Vodafone-340 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:1403:A006 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00B80000/00480000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:FFFFFF00000000 Backup required data Done ====> Patch required data ... .............................................. error: required unlock parameters not found, check model selection .............................................. error: required unlock parameters not found, check model selection Patch required data Fail Finished, time used: 47 sec Remove/Install battery now ! |
02-02-2011, 14:20 | #3 (permalink) |
Member: 997268 Status: Offline Sonork: 100.1661167 Thanks Meter: 113 | phone not power on sir backup write log here..... COM6 [VCP0] selected module v3.62 Device: Vodafone-340 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44__fullflash_part_1_of_1_20110201-235320.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:1403:A006 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00B80000/00480000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Vodafone-340__ffs... file saved: C:\Program Files\InfinityBox\MModule\Vodafone-340__ffs_20110202-050939.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required Special operation Done ====> Write ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00B80000/00480000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done Area: Firmware flash: EC257E25082501:FFFFFF00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization detected: BM35A1X1 customization: BM35A1X1 flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_44.BIN use default security area (sec info, hash) pattern error: can't assign default hash address range for ffs 00B80000/00001000 error: security area (sec info, hash) size is too small: 0000 error: can't calculate security area (sec info, hash) Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:2AEA0000000000 Finalization Done Finished, time used: 12 min 43 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
02-02-2011, 14:38 | #4 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | rewrite backup your fone and allways use unlock methaod smart fast for this modiols |
The Following User Says Thank You to naveedbutt For This Useful Post: |
02-02-2011, 14:43 | #6 (permalink) | |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Quote:
now fast repair securty aria ana then rewrite backup | |
02-02-2011, 14:48 | #7 (permalink) |
Member: 997268 Status: Offline Sonork: 100.1661167 Thanks Meter: 113 | repair security area.... COM6 [VCP1] selected module v3.62 Device: Vodafone-340 Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:1403:A006 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.3.62, database date: 01.10.2010): FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_44.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_44.BIN project-id: BM35A1.V2.22.M00.02.44, 00000000 code offset: 00000000 ffs offset/size [01]: 00B80000/00480000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00B80000 sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization detected: BM35A1X1 customization: BM35A1X1 flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_44.BIN use default security area (sec info, hash) pattern error: can't assign default hash address range for ffs 00B80000/00001000 error: security area (sec info, hash) size is too small: 0000 error: can't calculate security area (sec info, hash) Finished, time used: 49 sec Remove/Install battery now ! |
02-02-2011, 14:57 | #8 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | try to format ffs at complete mode if set is alive then u r lucky if not then u wait for infinty team answer about this thanks |
02-02-2011, 15:02 | #9 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | download this file from suport n flash it with new mm module like 3.73 |
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
02-02-2011, 15:27 | #11 (permalink) |
Member: 997268 Status: Offline Sonork: 100.1661167 Thanks Meter: 113 | thanks all solve mmodule v3.73 COM6 [VCP0] selected module v3.73 Device: Vodafone-340 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44_2010-09-03_En.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:1403:A006 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_44.BIN project-id: BM35A1.V2.22.M00.02.44, 00000000 code offset: 00000000 ffs offset/size [01]: 00B80000/00480000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00B80000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: BM35V2MP_MA7V28JR9BT71SDRPK7GS area1 is invalid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44__ffs... file saved: C:\Program Files\InfinityBox\MModule\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44__ffs_20110202-062214.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44__system_log__00000000_20110202-062227.B0X.bin Area: Firmware flash: EC257E25082501:2AEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization detected: BM35A1X1 customization: BM35A1X1 flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44__system_log__00000000_20110202-062338.B0X.bin Finished, time used: 6 min 55 sec Remove/Install battery now ! |
02-03-2011, 02:04 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @rana00 Yes, I think it was a problem that you have used very old version of Infinity-Box software. Please, always download and install latest version of Infinity-Box software because we add new features, firmware versions, hardware support at regular base. |
