Old 06-02-2019, 19:48   #1 (permalink)
Member: 50306
Thanks Meter: 51
bq aquaris x2 loader need
hi i have that log from infinity box
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : FFA648A5
ID_BLOCK_S : 1F8FCD13
ID_BLOCK_E : 41534D52
ID_BLOCK_L : D98CC0F5520DF5234F440622B310461F
ID_BLOCK_L : C70892586635AC8249904744FF0BAF65
Use CM2 Internal Loader
ERROR : Prepare target failed! Unsupported yet CPU!
INFO : Send log and report.log to support! Include device info also!
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Pickup loader from firmware package
FH_LOAD_CODE : 15
ERROR : Loader send failed!
HINT : Check cable, connection and drivers!
Reconnect Power/Cable!
i try loaders from xiaomi but not sucess,maybe somebody can read firmware twrp backup or somthing like that,dont need fastboot firmware because dont go to fastboot mode,recovery,pc dont recognize phone.i think i found edl testpoint because pc recognize qualcomm 9008 port and read that from phone.
Old 06-02-2019, 20:11   #2 (permalink)
Member: 1677653
Thanks Meter: 2,769
Can you share test point way?
Old 06-02-2019, 20:46   #3 (permalink)
Member: 50306
Thanks Meter: 51
bq aquaris x2 testpoint
https://ibb.co/5nRLy6B
Old 06-03-2019, 07:02   #4 (permalink)
Member: 1120289
Thanks Meter: 148
Originally Posted by cesarq View Post
Where is testpoint bro
Envoyé de mon SM-C7010 en utilisant Tapatalk
Old 06-03-2019, 10:54   #5 (permalink)
Member: 50306
Thanks Meter: 51
testpoint is there where i market black rounds with twizers short long time with the power-volume connector ground.battery is coneccted
Old 09-25-2019, 14:29   #6 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
you get the loader ?
Old 09-28-2020, 12:21   #7 (permalink)
..:: i-MAX ::..'s Avatar
Member: 94762
Thanks Meter: 115
any loader file for bq aquaris x2
Old 09-29-2020, 11:11   #8 (permalink)
Member: 72306
Thanks Meter: 193
if you load firmware from bq and open - you see this sdm636_fastboot_all_images.bat
Old 09-29-2020, 11:47   #9 (permalink)
Member: 94762
Thanks Meter: 115
but the loader it's look like "prog_emmc_ufs_firehose_Sdm660_ddr.elf"
not *.bat
Old 09-30-2020, 12:59   #10 (permalink)
Member: 72306
Thanks Meter: 193
i post name comand file for flash in fastboot - not loader
Old 07-13-2021, 08:52   #11 (permalink)
Member: 1210902
Thanks Meter: 231
https://disk.yandex.com/d/UaAQsZtdu3rzEA?w=1
The Following 2 Users Say Thank You to master353535 For This Useful Post:
Page generated in 0.18053 seconds with 9 queries
