06-12-2017, 17:05 | #1 (permalink) |
Freak Poster Join Date: May 2012 Location: GHANA
Member: 1759904 Status: Offline Thanks Meter: 6 | Please i need urgent help !!!!!!!! Please Chinese Miracle II [MTK module] v 1.58 User selected Preloader file : preloader_rlk6753_65u_m0.bin Operation : Init Preloader [ v1.58 ] Supported HW by Preloader : FlashID [0] CID : 90014A484147346132 , Name : HAG4a2 , Vendor : 90 , [HYNIX] FlashID [1] CID : 150100524531424D42 , Name : RE1BMB , Vendor : 15 , [SAMSUNG] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 450001704543414899150141D52EB928 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:32 Reconnect Power/Cable! User selected Preloader file : preloader_rlk6753_65u_m0.bin Operation : Init Preloader [ v1.58 ] Supported HW by Preloader : FlashID [0] CID : 90014A484147346132 , Name : HAG4a2 , Vendor : 90 , [HYNIX] FlashID [1] CID : 150100524531424D42 , Name : RE1BMB , Vendor : 15 , [SAMSUNG] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 450001704543414899150141D52EB928 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:21 Reconnect Power/Cable! * |
