09-24-2017, 08:02 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | infocus if9001 secured boot 7.0 frp remove sucessfully Card found : S/N : 94FBD840 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 49 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333145339A0D422799659A Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420D9A339A652427 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xECADEC527F392476E762C311733DE09F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : InFocus ProdName : IF9001_IN ProdModel : IF9001 Device : AA2 AndroidVer: 7.0 MTKxCPU : MT6737M MTKxPRJ : alps-mp-n0.mp1-V1.19_gr6737m.65.b.n_P50 SECURITY : IMEI_SW [1] : 357791080767075 IMEI_SW [2] : 357791080927075 BTMAC Addr : 98E79A600942 WiFi MAC : 98E79A6047C2 Done! Elapsed: 00:00:32 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 25 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 49 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333145339A0D422799659A Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420D9A339A652427 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xECADEC527F392476E762C311733DE09F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to galaxycompue For This Useful Post: |
09-24-2017, 12:39 | #7 (permalink) |
Member: 2298369 Status: Offline Thanks Meter: 440 | |
The Following User Says Thank You to galaxycompue For This Useful Post: |
09-27-2017, 13:43 | #10 (permalink) |
Member: 2298369 Status: Offline Thanks Meter: 440 | one thing i notice here, if u check info, locked with cert file handsets not supported but if signed with preloader then set connect properly in secure boot type handsets. |
09-27-2017, 16:35 | #11 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: Faisalabad Pakistan
Member: 696491 Status: Offline Thanks Meter: 164 | Request to jaydi sir !!!! Quote:
we should request sir jaydi till then new dish:d which he is cooking right now, he should give us supplement like nokia for manually choosing download agent and auth file to work on these phone. Other tool just give only this option and making noise on that behalf..... Nothing else ... I know for jaydi it's not a big game if he did that, lot of people will be happy and can do normal things like read pattern , remove frp or some thing like this. Please jaydi sir do this for us we believe on you, we love this tool and don't want to move on any other tool plzzzzzzzzzzzzz | |
09-27-2017, 22:03 | #12 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
All of that PLUS many more things are in preparation stage right now. You are gonna love it b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following User Says Thank You to Brka For This Useful Post: |
09-28-2017, 10:29 | #13 (permalink) |
Member: 696491 Status: Offline Thanks Meter: 164 | Brka: glad to see you here .. Thank you for replay, yes we are waiting anxiously for update. |
The Following User Says Thank You to netvision123 For This Useful Post: |
09-28-2017, 15:06 | #14 (permalink) |
Member: 2298369 Status: Offline Thanks Meter: 440 | now all box users know who start anything which is important to us like qualcomm module, infinity team give, so in secure boot area we also watching mtk new module, and i'm sure that this will also establish guideline to others how to work start in secure boot area, since other coders not know what is the present need of user, if i want to remove security lock of vivo v5, then if i have approach in service center then i install sp tool from there(one otp do register that tool in one computer), so if we hope where solution come out we only know one answer, from the side of infinity team, others are not doing a work in any new solution, only giving update to fool us, but we know who is the boss(may be infinity team or mr jaydi). |
10-11-2017, 00:07 | #15 (permalink) | |
Freak Poster Join Date: Nov 2005 Location: india
Member: 198115 Status: Online Sonork: 100.1591052 Thanks Meter: 15 | Quote:
can u pls help me i have same phone for frp which da file u used for secure boot | |
