Old 10-26-2008, 08:08   #1 (permalink)
dharmeshslnk's Avatar
Member: 385162
Thanks Meter: 598
Bsnl g200cf complete flashing success
BSNL G200CF COMPLETE FLASHING SUCCESS BY INFINITY SHOW THIS
COM6 [VCP0] selected
Device: Digibee-BSNL-G200CF
Checking data, wait...
Action: flash write
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-sta_20081025-115851.B1E.bin
loading data...
data loaded
reading [eeprom-sec]...
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-sec_20081025-115857.B1E.bin
reading [eeprom-complete]...
file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20081025-115904.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
Erasing: Firmware
Writing: Firmware
Erasing: Firmware
Writing: Firmware
Write Done
Finished, Remove/Install battery now !
Time used: 440 sec
PINOUT:=7,8=GRND
11=RX
12=TX
The Following 3 Users Say Thank You to dharmeshslnk For This Useful Post:
Old 11-07-2009, 13:45   #2 (permalink)
Member: 321173
Where are flasf files ???????????????????????
Old 11-08-2009, 02:35   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Here is an instruction how to get files from support area (3 (three) support area mirrors):
Old 03-15-2010, 05:40   #4 (permalink)
santhusystems's Avatar
Member: 1170625
Sonork: 100.1616527
Thanks Meter: 94
pinout
sir i want g200cf pinout image plz reply [email protected]
Old 03-15-2010, 05:41   #5 (permalink)
Member: 1170625
Sonork: 100.1616527
Thanks Meter: 94
i need pin outspinouts
Bsnl g200cf rx tx pinouts images ????????
Old 03-15-2010, 05:42   #6 (permalink)
Member: 1170625
Sonork: 100.1616527
Thanks Meter: 94
i need pinouts
Old 03-15-2010, 17:20   #7 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum
Old 04-08-2010, 07:26   #8 (permalink)
Member: 250973
Thanks Meter: 14
BSNL G200CF PIN OUT IMAGE BSNA G200CF PIN OUT IMAGE BY RAJESH on Flickr - Photo Sharing!
The Following User Says Thank You to RAVIVARMA For This Useful Post:
BSNL G200CF flash file mohit_kripalu01 Infinity-Box 14 02-16-2011 12:34
BSNL G200CF unlock problem bhuvanele Infinity-Box 38 05-17-2010 16:15
Help me , I am unable to unlock BSNL G200CF with infinity-box? gsm_surya Infinity-Box 4 01-06-2010 11:16
>>>> BSNL-G200CF Unlocked Successfully <<<< zeel_zeel Infinity-Box 1 12-02-2008 10:08
Help me , I am unable to unlock BSNL G200CF with infinity-box? gsm_surya Infinity-Box 3 04-11-2008 09:38
Page generated in 0.21758 seconds with 10 queries
