12-04-2008, 12:48 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Bangalore, Karnataka, india Age: 37
Member: 845234 Status: Offline Thanks Meter: 364 | BSNL g200cf unlock done 100% COM6 [VCP0] selected module v1.56 Device: Digibee-BSNL-G200CF Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: ULC2GL N W 0 A X 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-sta... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-sta_20081204-171443.B1E.bin loading data... data loaded reading eeprom-sec... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-sec_20081204-171446.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20081204-171453.B1E.bin reading additional data... done backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 53 sec Remove/Install battery now ! |
The Following User Says Thank You to ms_ahmed For This Useful Post: |
12-04-2008, 13:32 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
12-31-2008, 15:05 | #3 (permalink) |
Freak Poster Join Date: Dec 2006 Location: INDIA
Member: 416940 Status: Offline Thanks Meter: 173 | THANKS infinity box best box of the year and ever COM28 [VCP1] selected module v1.57 Device: Digibee-BSNL-G200CF Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL N W 0 A X 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20081231-192905.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20081231-192906.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20081231-192912.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_lock-area_20081231-192919.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 38 sec Remove/Install battery now ! |
12-31-2008, 15:06 | #4 (permalink) |
The Following User Says Thank You to luqmaan751 For This Useful Post: |
12-31-2008, 15:56 | #5 (permalink) |
BSNL G200CF unlock | ChandruChiyyan | Infinity-Box | 2 | 07-20-2011 09:22 |
BSNL G200CF unlock problem | bhuvanele | Infinity-Box | 38 | 05-17-2010 16:15 |
>>>> BSNL-G200CF Unlocked Successfully <<<< | zeel_zeel | Infinity-Box | 1 | 12-02-2008 10:08 |
Bsnl g200cf unlocking good with et-box | sahil2000ind | ET-BoX | 3 | 10-12-2008 15:25 |
bsnl g200cf unlocking problem | shaik.shabeer | Infinity-Box | 2 | 10-07-2008 17:09 |
