Old 09-03-2016, 00:59   #1 (permalink)
Member: 2392531
Thanks Meter: 5
Exclamation BUG - Cannot format CACHE with CM2MTK v1.55
CM2MTK v1.55
When Factory Resetting a phone it will format the USERDATA but it fails to format the CACHE, it doesn't start it only freezes the software.
To get over this issue i used CM2MTK v1.53 and it formatted the CACHE
Here is the log:-
Start at : [02-Sep-16 / 6:48:00 PM]
Operation : Format FileSystem [ v1.55 ]
Wait for phone...
Phone found! [ 133 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483847316505077DE9205592B7
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505077DE9205592B7
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xAAE84266E3D211DEC3078ECEDC5FB11B
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
The program freezes and i have to Force-Close
Start at : [02-Sep-16 / 6:49:58 PM]
Operation : Format FileSystem [ v1.53 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:31
Reconnect Power/Cable!
Finish at : [02-Sep-16 / 6:50:30 PM]
Old 09-03-2016, 01:12   #2 (permalink)
Member: 219803
Sonork: 1582317
Thanks Meter: 38
Yeb same problem here I faced it many times and now am using the previous version
Sent from my SM-N920C using Tapatalk
Old 09-03-2016, 01:23   #3 (permalink)
umargee's Avatar
Member: 1075413
Sonork: 100.1656923
Thanks Meter: 149
same problem
but I have a solution
use 1.54v
Old 09-03-2016, 11:40   #4 (permalink)
bronce's Avatar
Member: 488875
Sonork: 100.1626294
Thanks Meter: 1,129
same here....................
Old 09-03-2016, 12:07   #5 (permalink)
Member: 2501288
Thanks Meter: 328
same problem soft stuck at clear cache
Old 09-03-2016, 14:33   #6 (permalink)
Member: 2195211
Thanks Meter: 4,294,967,295
may be it will be clear in update version
Old 09-03-2016, 14:45   #7 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
BUG informed ..... will fix on next update
Br - srinibas
The Following 2 Users Say Thank You to srinibas For This Useful Post:
Old 09-03-2016, 14:53   #8 (permalink)
Registered User
Member: 2506300
Thanks Meter: 345
i have same problem.....v1.55 ........
Old 09-03-2016, 15:21   #9 (permalink)
papsnew's Avatar
Member: 390521
Thanks Meter: 57
so you use V1.54 ......am sure support have noted this....
Page generated in 0.26477 seconds with 9 queries
