04-24-2016, 14:41 | #1 (permalink) | ||
Freak Poster Join Date: Jan 2014 Location: india
Member: 2111064 Status: Offline Thanks Meter: 21 | BUG IN CM2MTK! problem after flashing HTC D626q MEMORY GONE! this pc came to me with hang on logo and i took a backup of nv ram and flashed an orignal file thru this tool! the flashing went fine! Quote:
I TRY user memory repartiton thisnking this might fix but; Quote:
see attached pics both in this link below! https://XXX.camscanner.com/share/qjXpn/0/w105s190sws5t pls fix this problem! wbr atstech. | ||
04-24-2016, 15:50 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Less hysterical. For start. Check device version. There is 8 and 16 GiB devices. In some cases FW can have both scatters - 16 and 8. Flashing 16 will give 16 GiB memory for 16GiB emmc and flashing 8Gib will give 8Gib memory on 16 GiB eMMC. |
04-24-2016, 17:16 | #5 (permalink) | |
Member: 2111064 Status: Offline Thanks Meter: 21 | Quote:
im not here to tell you your tool is bad, im just informing you your tool is good and this is a bug when u fix this it will make your tool much better! | |
04-24-2016, 18:13 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Scatter have parted to 1.3 GiB user memory Btw - fw seems as factory one, or made by someone? CM2 will make correct one on FW reading attempt. Not sure about support such cases in future - one case can't give enough reasons for that. |
04-24-2016, 18:37 | #9 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | @atstech Dear brother next time try to read firmware. before any operation, even if its HANG ON LOGO! (its usefull ) If operation goes well you delete it !! |
