06-16-2010, 11:50
#1 (permalink)
Member: 198621
Sonork: 100.1591649 Thanks Meter: 1,083 | Bug in MMODULE v3.44 ! Error unlocking ot303 alcatel: Quote:
COM1 [VCP0] selected
module v3.44
Device: Alcatel-303X, 303A
Checking data, wait...
advanced flash detection disabled
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:B195:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98004900000002:2BEA0000000000
flash: Toshiba TV00578002DABD T 8Mb
otp offset: 007F0000
detecting chip #01 in region #00...
flash: 98004900000002:311F8E00000000
number of flash chip/regions detected: 02/01
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.ABBFC 670.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_9D550205].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: ABBFC670
rom info ver: 05
sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN
project-id: MAUI.08A.W08.36.SP1.V9, 0502559D
code offset: 00000000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 169
provider: 303X-2ARGTE1
customization: CI16CD03
customization: XI16CD03
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, cust) calculation...
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: F4B67AB6FFC675
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
error: wrong erase first sector at 0x00C00000
error: format ffs failed
Finalization Fail
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-303X,303A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V9__system_log_ABBFC670_9D550205_2010 0616-103931.B0X.bin
Finished, time used: 2 min 7 sec
Remove/Install battery now !
