07-10-2007, 13:23 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Age: 42
Member: 426680 Status: Offline Thanks Meter: 11 | C 123 SP lock COM17 selected Action: unlock Device: C122, C123 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 what is the solution of this problem waiting for reply Last edited by InfinityHelp; 07-10-2007 at 14:28. |
07-10-2007, 14:27 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Hello! if cable is tested, if you sure about evrything else like comport settings etc... if you made many phones, but this one is not connecting this means Test point must be cut. |
07-10-2007, 16:41 | #5 (permalink) | |
Freak Poster Join Date: Jul 2006
Member: 314780 Status: Offline Thanks Meter: 12 | Quote:
Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 1.0.81.E. HW version: _E88 imei otp: 353905017664098 Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_353905017664098_20070623-175246.18E.bin imei eeprom: 353905017664098 Codes: 37318403 29158403 Finished, time used: 14 sec Remove/Install battery now ! good luck . | |
I WILL UNLOCK SP LOCK AND LOCKS 1234 FOR U | andrew bennett | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-01-2011 09:21 |
N70 SP Locks STATUS: SP DATA IS corrupted | Nasmi | Nokia Base Band 5 ( BB-5 ) | 6 | 05-15-2007 15:20 |
Change back Sp lock to locked state ? | tkerek | x1x to x45/x50 | 0 | 01-17-2002 16:28 |
