04-09-2009, 15:37 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: on forum
Member: 566122 Status: Offline Thanks Meter: 322 | C-139 not unlock |
The Following User Says Thank You to aminnovelty For This Useful Post: |
04-09-2009, 15:40 | #2 (permalink) |
No Life Poster Join Date: Dec 2008 Location: PUNJAB Age: 41
Member: 914898 Status: Offline Sonork: 100.1597109 Thanks Meter: 117 | How to fix C113-C118, C138, C139, C140 boot error “version mismatch other connection settings should be used”. If you see boot error “version mismatch other connection settings should be used” make this: 1. Go to software “Settings” page. 2. Change connection mode (try to use all connection modes one by one). |
The Following User Says Thank You to experttelecom For This Useful Post: |
04-09-2009, 18:36 | #3 (permalink) | |
C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ Unlock_Moto-C139_TracFone-8.8.17_C113-C118-C123_2.2.83_and_newest.htm | |
04-10-2009, 10:24 | #4 (permalink) |
Member: 914898 Status: Offline Sonork: 100.1597109 Thanks Meter: 117 | select method 4 COM4 [VCP0] selected Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 02 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 1.3.29 HW version: _E88 LP ver: LPH_C139_ASIA2_Z1C Flex ver: FFH_C139_67_Z1C imei otp: 351975010911632 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _351975010911632_20090410-024304.31E.bin imei eeprom: 351975010911632 extra method pass-1... reading ... extra method pass-2... Check Flash-2 Done Write... Write Done Finished, time used: 63 sec Remove/Install battery now ! select method 4 |
The Following 2 Users Say Thank You to experttelecom For This Useful Post: |
04-11-2009, 06:44 | #5 (permalink) | |
Member: 566122 Status: Offline Thanks Meter: 322 | Quote:
my black berry 8100 is not unlock (Answered) | ravin j tejura | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 11 | 04-08-2010 15:05 |
Nokia E65 not unlocked!! | zeemar | Cyclonebox | 8 | 03-30-2010 12:59 |
lg bl20 not unlocking | simlock | Z3X-Team Products | 1 | 03-29-2010 18:47 |
C-139 not connected? | aminnovelty | Infinity-Box | 3 | 01-29-2009 12:17 |
BE4-139 Dump unlocker, someone has tested it? | ags28 | Alcatel & TCL Old Models | 1 | 04-03-2002 13:17 |
