09-22-2007, 11:23 | #1 (permalink) |
Registered User Join Date: Sep 2006
Member: 347872 Status: Offline Thanks Meter: 5 | C 168 can't conect with my box???? |
09-22-2007, 13:55 | #3 (permalink) |
Member: 347872 Status: Offline Thanks Meter: 5 | Cable and Com port setting was Ok,I can flash another phone like C 261 and phone was conect no problem???But c 168 not conected,Btw or need testpoint method sir for this phone??? |
09-24-2007, 17:28 | #7 (permalink) |
Member: 347872 Status: Offline Thanks Meter: 5 | this is log : COM10 [VCP3] selected Device: Motorola C168 Checking data, wait... Action: flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Before conection no problem,after phone was died not conect until now, For cable N setting com port Ok I flash many phone like C261 n Panasonic X66 no problem N working. Batray Full N some time I use power suplay but sam not conected. |
09-24-2007, 18:33 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! c168 can not be killed by wrong flshing. If battery is ok. cable tested, com port is selected properly- only possible error is some internal hardware fault |
09-24-2007, 20:40 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! is your cable modifyed? maybe it is not fitting in handsfree port properly. try to cut rubber like it is shown on G50 cable picture. select panasonic G50 model in shell.exe check pinout picture number 2 and 3. modify your cable same way. also when program ask to power on phone push cable inside phone and then push power button |
09-24-2007, 21:03 | #11 (permalink) |
Member: 347872 Status: Offline Thanks Meter: 5 | No problem with the cable sir,i have 2 pcs C168 And one of them conected and Workproperly in my box ,for C168 Not conected same problem like this : http://forum.gsmhosting.com/vbb/showthread.php?t=443150 |
Can't conect with rj45...please solution | awenaw | Z3X-Team Products | 11 | 01-09-2010 13:16 |
kp 500... i can't conect on my polar box> [ANSWERED] | jermaineyork | PolarBox 3 | 2 | 01-04-2010 06:47 |
8310 still can't conect with pc | jupizet | BlackBerry (RIM) | 9 | 03-13-2009 18:22 |
HELP with my HUG Q-23 can't find with my pinfinder! | jaye_patok | Infinity-Box | 8 | 02-01-2009 17:51 |
6230i..power on ONLy conect with JAF box... | stefani | Nokia Hardware & Hardware Repair | 5 | 03-24-2008 18:55 |
