08-16-2009, 21:17 | #1 (permalink) |
No Life Poster Join Date: Aug 2005
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | c1100 restart after flash module v1.38 Device: LG-C1100 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 98008400000032:FEEA0000000000 flash: 98008400000032:FEEA0000000000 flash: Toshiba B 8Mb id: 00005250 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 356192003514036 file saved: G:\Program Files\InfinityBox\LGA\eeprom_356192003514036_LG-C1100_20090816-225837.B1E.bin ........... version: ser-AgentLG-C1100MICWA reading ser-AgentLG-C1100MICWA_eeprom-ffs_356192003514036... file saved: G:\Program Files\InfinityBox\LGA\ser-AgentLG-C1100MICWA_eeprom-ffs_356192003514036_LG-C1100_20090816-230355.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 360 sec Remove/Install battery now ! COM25 [VCP0] selected module v1.38 Device: LG-C1100 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" active "keep calibration" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 98008400000032:FEEA0000000000 flash: 98008400000032:FEEA0000000000 flash: Toshiba B 8Mb id: 00005250 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 356192003514036 file saved: G:\Program Files\InfinityBox\LGA\eeprom_356192003514036_LG-C1100_20090816-231242.B1E.bin ........... version: ser-AgentLG-C1100MICWA Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) flash: 98008400000032:FEEA0000000000 flash: 98008400000032:FEEA0000000000 Write: Alchemy data flash: 98008400000032:00000000000000 flash: 98008400000032:00000000000000 Write Done Finished, time used: 1467 sec Remove/Install battery now ! initially phone was ok witout sim, restart with sim!!! |
C1100 freez after flashing | aplauz | Blazer | 10 | 09-07-2006 05:34 |
**c1100 haging after flash** | infogsm | FuriouS II | 1 | 04-02-2006 22:15 |
T630 Restart After Flash | nilan | Cruiser Suite | 7 | 04-19-2005 23:20 |
nec 616 restarting after flash and unlock | codec_romania | NEC | 3 | 03-24-2005 08:31 |
A35 restarting after flash | Ayush | x1x to x45/x50 | 4 | 07-09-2003 12:57 |
