Old 04-24-2006, 15:00   #1 (permalink)
Member: 33690
C113 Catastrophy
Hello,
Try To Solve This Problem And Do Dont Post Links To Solutions Written In Threads. I Have Read All. I Have Tested On 5 Computers And Used 4 Com Cables, Used Three Infinity Different Dongles, Used Cables That Came With Infinity Box. Still Cannot Unlocked A Single Motorola C113 Phone. Tested Cables On T191 And All Are Okay. Infinity Team, Try To Make A Faster Way For Unlocking These Phones. So Many Headaches Using The Moto Software. Have A Nice Day.
Old 04-24-2006, 15:50   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Hello,
Yes, just want to confirm that in some cases it's quite hard to use uniboxes (supplied in our package) with Moto C115 and C139.
To avoid any problems with C113 just make this (it's 100% solution, confimed by more than thousand of users):
1. be sure that your cable COMPLETELY inserted in C113 (because some cables has so big rubber around metal pin).
2. Check "Documentation" folder and adjust COM-port settings
or
3. use ordinary COM-port cable
or
4. use Prolific-based usb-rs232 converter
It's no need to try different Infinity-Box dongles: all our dongles is absolutely the same.
It's no need to use different PC, it's not depend on PC.
Just follow to my preious advices and you will be able to unlock so many C113 as you wish.
Old 04-24-2006, 16:02   #3 (permalink)
Member: 130995
Btw, when you tested 3 more Infinity-Box dongles, did you found the same problem like with your first box (I mean problem that you had yesterday with box and bad soldered sim-card holder inside box) ?
Old 04-24-2006, 16:04   #4 (permalink)
Member: 33690
Hello
Hi,
Sure, I Did All Those. I Am Using T191 Com Cable. See The Settings Here. Why Is C113 So Different. Have A Nice Day.
Old 04-24-2006, 16:07   #5 (permalink)
Member: 33690
Hi
@InfinitySupport
Btw, when you tested 3 more Infinity-Box dongles, did you found the same problem like with your first box (I mean problem that you had yesterday with box and bad soldered sim-card holder inside box).
THESE DONGLES IS FOR A FRIEND. IT IS USB EXTERNAL DONGLE, NOT INSTALLED INSIDE BOX. HAVE A NICE DAY.
Old 04-24-2006, 16:23   #6 (permalink)
Member: 45682
hello
your cable t191 u must cut littile from the cable head plastic
if need work in c113
br
Old 04-24-2006, 16:32   #7 (permalink)
Member: 130995
Originally Posted by ahmedksal
Hi,
Hi,
Just want to explain small difference between plain COM port cables and usb-rs232 convertes (your screenshot was made for USB-RS232 FTDI-based converter, not for plain COM port, not for PROLIFIC-based converter):
1. FTDI usb-rs232 converter: used in unibox. cable connected to USB PC port
2. plain COM-port: cable that has DB-9 connector and connected directly to PC COM port DB9 connector
3. Prolific usb-rs232 converter: PL2303 chip used. cable connected to USB PC port
Please, use cables described in '2.' or '3.', not '1.'.
Old 04-24-2006, 16:53   #8 (permalink)
Member: 33690
Hello
Hi,
How Can You Set When You Are Using Com Cable. Have A Nice Day.
Old 04-24-2006, 16:58   #9 (permalink)
Member: 130995
It's no need to adjust any settings for ordinary COM port cable.
It's better to use cable with external power (it's professional choice - use cables with extrnal power). If you still have problems with COM port cable and if your COM port cable w/o external power make this: try to change RTS/DTR settings in our software (menu -> file -> ...).
Old 04-25-2006, 08:25   #10 (permalink)
Member: 33690
Again
Hello,
Tried All This. I Tested On 5 New C113 Phones But No Luck. Any Ideas, Thanks And Have A Nice Day.
Old 04-25-2006, 09:18   #11 (permalink)
Member: 130995
Hello,
And what software say after all tries ?
If it's still no luck try to make this: adjust connector to be sure that it's fit in phone completely. picture you can find here:
"x300 problem"
if still no luck I can offer other easy way: it's not a secret that there are a lot of links to original C115 flasher named "DMTool". Try to use it. It can be that it will works in your case with your cables.
You can find a lot of links to "DMTool" in this forum "ODM Motorola" section.
Old 04-25-2006, 09:27   #12 (permalink)
Member: 79725
Hi,
as mohammadmouazen say
the t191 cable plasitc cover of cable pin is more than c113 cable.
so u must cut littile from plastic connector to make the cable fit inside phone littile more .
test and u not lose .
b.r.
Old 04-25-2006, 12:24   #13 (permalink)
Member: 33690
Hello
HI,
STILL THE SAME. NO LUCK. AND IF I NEED TO USE DMTOOLS. WHAT IS THE USE OF YOUR DONGLE. AFTER PRESSING STOP, THIS IS WHAT I RECEIVE
Action: Unlock
Device: C113,C115,C116,C117,C118
Checking data, wait...
Connect...
Press and HOLD Power button...
Err: boot[02]:
Release Power button !
Connect Fail
Failed !
Finished
Remove/Install battery now !
Time used: 23 sec
HAVE A NICE DAY.
Old 04-25-2006, 12:25   #14 (permalink)
Member: 33690
Hi
@mtmc
HI, CHECK POST NO 8 AND HAVE A NICE DAY.
Old 04-25-2006, 12:42   #15 (permalink)
Member: 130995
HI,
....skipped...
Hello,
Yes, it was an answer that was expected by me exactly.
I am very sorry that you have so bad experience with C113 and Infinity-Box software (but to be honest, thousands of people have no such problems).
My small answer to your question is:
List of Supported phones by Infinity-Box
As about your five new C113 phones:
If you want to unlock your phone - just use my last advice and make a job. And, please, post results here. We are always glad to hear about problems/bugs in our software (if really exists) so any your comments are welcome ! For sure our programmers will work more and more harder to remove all possible bugs and make our box more and more powerfull.
You are really hardworking person (you have made a lot of photos, screenshots and tests to make C113 unlocked) so, please, make final test by my advice and I hope you will be satisfied with results. My advice you can see in post #11.
Thank you for understanding !
and... have a nice day !
Infinity Box Catastrophy ahmedksal Infinity-Box 10 12-19-2006 13:57
Catastrophy With Motorola ahmedksal Motorola P2K (USB-Smart) 4 05-31-2006 21:56
V980 Catastrophy ahmedksal Smart-Clip 2 04-02-2006 14:07
Sx1 Catastrophy ahmedksal E-Gold Based Phones 1 03-20-2006 18:55
6600 Catastrophy ahmedksal UFS2 + UFS3-Tornadoflasher 5 12-04-2004 11:19
Page generated in 1.01796 seconds with 12 queries
