07-12-2006, 22:59 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Inside facebook Age: 47
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | C113 v2.3.65 problem!!! This is what I get as error when unlocking some phone. After cut testpoint and start repair module COM2 selected Device: Moto C113,C115,C116,C117,C118 Checking data, wait... Action: Flash write Write: Repair data Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:88C2 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0089:88C2 Err: answer#FF try#02 to recover write error at 0000E000 Err: answer#FF try#03 to recover write error at 0000E000 Err: answer#FF try#04 to recover write error at 0000E000 Err: answer#FF try#05 to recover write error at 0000E000 Writing Done Finished Remove/Install battery now ! Time used: 36 sec or COM2 selected Device: Moto C113,C115,C116,C117,C118 Checking data, wait... Action: Flash write Write: Repair data Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:88C2 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0089:88C2 Err: no answer Writing Fail Finished Remove/Install battery now ! Time used: 27 sec still have same problem COM2 selected Device: Moto C113,C115,C116,C117,C118 Checking data, wait... Action: Flash write Write: Repair data Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:88CE Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0020:88CE Err: no answer Writing Fail Finished Remove/Install battery now ! Time used: 24 sec BR Last edited by snsoftkiller; 07-12-2006 at 23:58. |
07-13-2006, 04:09 | #2 (permalink) |
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | Done 32 pcs tonight but still have problem with 4pcs. To be honest, I'm very happy with my box. But help me to resolve this problem asap. BR |
07-13-2006, 05:50 | #3 (permalink) |
No Life Poster Join Date: Dec 2002 Location: ...where eagles fly...
Member: 19267 Status: Offline Thanks Meter: 101 | mine not connected after cutting TP. pls i need to ask... will phone be dead or alive after TP? can it connect with x60 cable only? NB: i read track that i cut there is no continuity, so means track is cut yet phone still powers. Rgds |
07-13-2006, 21:37 | #4 (permalink) |
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | If tp is correctly cut phone look like dead. I'm using simple C115 cable, don't use x60 cable. Try with data cable or use your universal box. Last edited by snsoftkiller; 07-14-2006 at 02:19. |
07-15-2006, 19:11 | #5 (permalink) | |
to be honest: can't imagine what can be wrong. Try to use fully charged battery. If phone can connect to RepairModule this means that track cutted correctly. | |
C113 v2.2.63.N - can't unlock | sm@sh | Motorola ODM | 7 | 11-02-2006 01:46 |
Need N70_APAC_V3.0546.2.3 and 6270 3.65 apac | suriyon | MT-BOX | 2 | 01-21-2006 13:06 |
s25@once v2.0.3 v2.3.2 help | conka | Siemens-Benq RingTones and WallPapers | 1 | 01-18-2005 07:32 |
VisSie v2.3.0b problem... | bgcngm | Siemens-Benq RingTones and WallPapers | 12 | 04-28-2004 22:30 |
All New Sagem unlocker V2.3 problem | andrews | ARM9 BASED M62 / M62+ | 6 | 08-04-2003 18:56 |
