11-07-2006, 08:36 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: SALMAN SOFTWARE SADDAR RWP
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | c115 unlock code can't read y2ksalman |
11-07-2006, 09:31 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, probably you c115 has new firmware version. check this: http://forum.gsmhosting.com/vbb/showthread.php?t=310686 |
11-07-2006, 11:15 | #3 (permalink) |
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | sir i have this version which are u showing me in thread but can't booting and using new infinity box with 14 cables using x60 cable y2ksalman |
11-07-2006, 11:41 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. What is your phone firmware version ? 2. Did you checked this link carefully: http://forum.gsmhosting.com/vbb/showthread.php?t=310686 |
11-08-2006, 10:31 | #5 (permalink) |
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | sir i m using v1.20 and it giving me this error COM1 selected Action: Read code Device: C113,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... after this when i prees the button set comes on but still not gaving any codes plz tell me wats the problem y2ksalman |
11-08-2006, 10:49 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | PLEASE, READ THIS: 1. What is your phone firmware version ? 2. Did you checked this link carefully: http://forum.gsmhosting.com/vbb/showthread.php?t=310686 |
11-08-2006, 11:43 | #7 (permalink) |
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | sir i read it very care full fone version i can't find where is it i just s [Infinity Box]v1.20 sir this is very very hard work 4 me i bought the infinity box still from 2 month but i can't work on this still not read codes y2ksalman |
11-08-2006, 11:47 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. What is your phone firmware version (press #02# to see it) ? 2. You must read and understand this: http://forum.gsmhosting.com/vbb/showthread.php?t=310686 |
11-08-2006, 13:01 | #9 (permalink) |
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | 001F2013 438200795119 who: sw_cm this is the firmaware sir i m really happy that u r very serious to guide me and i m very very thank full to u but u r gaving me link the link is send in june i perchase the box in october i have a latest version i also format ffs but no response y2ksalman |
11-08-2006, 14:16 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. What is your phone firmware version ? Press #02# and then use up/down keys to find version. Post here all info that you see on LCD. Version looks like x.x.x 2. You must read and understand this: http://forum.gsmhosting.com/vbb/showthread.php?t=310686 |
11-08-2006, 15:01 | #11 (permalink) |
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | sir this seem i m really in confuse now i c full firmware 28 sep 2004 sw ver:3.0.22.E FFE_C115_27_116 LPE_C115_ASIA4_316 DOM1:200409120851 DOM2:200409130851 DOM3:000000000000 InVCC"0 TFT: 457D 6H10m Fail_counter = 0 this is the full firmaware cersion of set sir |
11-08-2006, 17:15 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Phone firmware version is 3.0.22.E I think you have communication problem that can be solved by this method: C115, C116, C139 bad connection: http://forum.gsmhosting.com/vbb/showthread.php?t=309557 http://forum.gsmhosting.com/vbb/showthread.php?t=290589 http://forum.gsmhosting.com/vbb/showthread.php?t=271431 Please, read instruction in yellow window (you will see it for sure when you start software). if you can't solve the problem by above mentioned methods, you must use this method: http://forum.gsmhosting.com/vbb/showthread.php?t=310686 I hope this time my description is more than enough. Anyway, if you will have any problems and you don't have 5 minutes to read "FAQ" thread in this forum, I'll be happy to give you more detailed description. I hope you will be able to post text from software log window here next time when you will have a problem so I can see what is wrong. |
vodavone 830 with fone code can't read it by FG | LordMen007 | FuriousGold | 11 | 01-14-2010 21:58 |
7370 can't unlock and can't read simlock status with cyclone box !! | wgmmmx | Cyclonebox | 10 | 05-21-2009 13:13 |
Can't Unlock and can't read flash my433v | said4 | SMTi | 1 | 05-20-2009 04:54 |
c115 unlock code | taariqmajid | Smart-Clip | 4 | 08-02-2005 10:07 |
c115 unlock code | Keke | Motorola ODM | 0 | 01-06-2005 12:37 |
