C116 Phone Hacked Hi today i got a C116 with freeze problem so i decide to flash phone. I used the following flash files: C115_2.2.80N_Main.18M C115_2.2.80N_Flex_FFN_C115_2I_X74_Claro_704-01.18F C115_2.2.80N_LPN_LATAM_Z74_En_Es_Pt.18P After flashing when i turned on the phone i got phone hacked and cant repari it RJ-45,USB or Serial none of them read the phone... Pls advice me what do. Here is log: COM15 [Serial2] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 2.0.51.N. HW version: _E88 imei otp: 010725009393661 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Archivos de programa\InfinityBox\Moto01\backup_eeprom_calibrat ion_010725009393661_20090211-090224.18E.bin imei eeprom: 353518000868848 Check Flash-2 Done Write... Writing: all flash areas Write Done Finished, time used: 240 sec Remove/Install battery now ! Thanks in advance BR, Tito Millo |
rajesh ch. |
Br, Shadab Ahmad |
The problem is that now phone cant be reconized by soft evey time i try to conect with soft phone turn on and nothing happens its like port is blocked....i have tried with USb,RJ-45 and Serial cable but no luck BR, Tito Millo |
cut track r remove boll then connect only flsh eeprom from support make jumper cutted r make boll power on 100% tested |
p.s sorry to say but for such a cheap phone i dont think its a good idea.for next time please flash phone with 1.x.x version files |
Yes its a cheap phone but i will try to repair it cutting track Thanks for advice BR, Tito Millo |
