12-21-2006, 13:44 | #1 (permalink) |
Freak Poster Join Date: Sep 2004 Location: India Age: 49
Member: 83476 Status: Offline Thanks Meter: 11 | C117 dead after repair bin |
12-21-2006, 13:59 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, steps to repair dead c117 phone: 1. check your PC keyboard, probably it's damaged (at least "CAPS LOCK" key must be repaired urgently) 2. charge phone battery (use other phone or external power supply) 3. start "RepairModule" and repair dead bootzone according to instruction from RepairModule/Documentation folder 4. restore cutted track 5. flash phone by ordinary way |
12-21-2006, 14:27 | #3 (permalink) |
Member: 83476 Status: Offline Thanks Meter: 11 | [QUOTE=InfinitySupport;2155424]Hello, THANX FOR REPLAY ,WITCH FLASH V I HAVE TO FLASH THERE IS NO C117 FERMWARE ON SUPPORT IS C115 CAN BE USE FOR THIS IF YES PLEASE WHAT V I CAN USE |
12-22-2006, 07:41 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | as ordinary, from www.infinity-box.com support area at least caps lock key already repaired, it's first good result. but the question... |
12-22-2006, 07:57 | #8 (permalink) |
Member: 83476 Status: Offline Thanks Meter: 11 | please direct link for repair module & my keboard is fine just now i unlock two c117 & one c139 without problem ,is it possible to repair this dead c117 without cut track? (with full flashing main,lp,fex with INFINITY) |
12-22-2006, 09:04 | #10 (permalink) |
Product Supporter Join Date: Mar 2005 Location: in CPU
Member: 128745 Status: Offline Thanks Meter: 16,936 | For C113, C115, C117, C118 there are 2 types of dead phone 1) Dead phone WITHOUT boot erased This can be repaired just by flashing main + lp + flex ( No need cut track) 2) Dead phone WITH boot erased To repair this you must use CUT TRACK METHOD ( Use repair module) When you have a dead phone , first try option 1 if no sucesss then repair by option 2 |
12-22-2006, 09:06 | #11 (permalink) | |
to cut... or not to cut... it depends on firmware version. how to check firmaware version ? here is the code: #02#* possible or not ? check "sticky" threads, read FAQ, use "search" and you will get detailed info. | |
12-22-2006, 09:31 | #12 (permalink) | |
Member: 83476 Status: Offline Thanks Meter: 11 | Quote:
regards | |
C117 dead after unlock | muksforu | Infinity-Box | 4 | 06-21-2006 13:17 |
BENQ S660C LCD Dead after repair Eep !! | flechazo | VygisToolbox | 3 | 09-07-2005 19:06 |
Fisio 535 (O2) Dead after repair Flash !!!! | dannyogolo | Redbox | 7 | 04-03-2005 17:11 |
Sony J70 deads after repair imei | barvik | Sony Ericsson Hardware Repair | 0 | 03-24-2004 22:59 |
bf3 dead after repair result blanc screen | Chawkiz_gsm | BF, BG, TH, BHx Series | 5 | 05-31-2003 10:09 |
