c117 flex code error when the phone was being unlocked it stated some error and now when the phone is powered on the display just says flex code error.... plz help.............. and again i tried to unlock the phone is still in the same state but the logs says ? :confused: :confused: :confused: COM3 selected "smart write" active Action: unlock Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode[00] Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 2.5.78.N. HW version: _E88 imei otp: 353618012073237 Check Flash-1 Done Check Flash-2... reading ... file saved: Backup_eeprom_calibration_353618012073237_2007-2-10_17-14-19.18E.bin imei eeprom: 353618012073237 extra method pass-1... reading ... extra method pass-2... Check Flash-2 Done Write... Write Done Finished, time used: 19 sec Remove/Install battery now ! |
Tri to flash (main+flex+lp) yesterday solved this problem. B.r. Sunil. |
