-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   C139 : Phone Is Hacked (http://forum.gsmhosting.com/vbb/f296/c139-phone-hacked-448468/)
supremegsm 09-28-2007 11:05
Hi All
I Have A Motorola C139 Handset Showing Phone Is Hacked. I Have Flashed With The Latest Firmware+flex+lp (ver. 1.3.29, ) & Eeprom Ver 13.39e. But The Problem Remains The Same. I Have Searched The Posts But The Only Method Posted Is Flash Firmware Pack , Which Is Not Helping.
InfinitySupport 09-28-2007 11:29
flash phone with 1.x.x firmware and make "unlock" procedure
supremegsm 10-03-2007 12:29
Hi
I have tries flashing with different Main+LP+Flex (1.3.28 ver)..But Problem remains the same. Also when I try to flash the Repair EEPROM
it says "error: flash chip detection problem".Have checked the model no correctly and flASHED.
COM14 [VCP0] selected
Action: flash
Skip: Firmware
Skip: Language Pack
Skip: Flex
Write: Eeprom
Device: C139,C140
Checking data, wait...
Connect...
Press and HOLD Power button...
connection mode: 02
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
921600
Set Baud Done
Check Flash-1...
startup condition detected
SW version: 1.3.28
HW version: _E88
LP ver: LPL_C139_LATAM_Z1B
Flex ver: FFL_C139_3W_X1B
imei otp: 357251005406408
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: backup_eeprom_calibration_357251005406408_20071003-155354.31E.bin
imei eeprom: D596F35420ABA7F
Check Flash-2 Done
Write...
Writing: Eeprom
Write Done
Finished, time used: 14 sec
Remove/Install battery now !
Please post solution ..
InfinitySupport 10-03-2007 15:09
Flash phone with 1.0.x flash files set and make unlock
::gsmcoder:: 12-22-2007 18:32
Simple, Phone Needs To Be Flashed Back To Version 1.
akash_hul 05-07-2008 14:11
soilve ur prob
flash with 1.0.3***
amol_sm 05-07-2008 14:49
Dear flash the phone with last uploaded version (Last upload by date)
U r problem will be solve.
Post result.
jakoy 06-24-2008 09:49
it done by restoring eeprom... work fine
Page generated in 0.19769 seconds with 5 queries
