05-31-2007, 12:51 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Sao Paulo - BRAZIL Age: 49
Member: 26751 Status: Offline Thanks Meter: 2 | C139 problem I tried to unlock a Motorola C139 (850/1900) but after unlocking phone does not turn on anymore. Any idea about how to fix that?? Thanks in advance, UnlockBR |
06-01-2007, 01:30 | #3 (permalink) |
Member: 26751 Status: Offline Thanks Meter: 2 | Battery is ok. Here goes log: Log opened: [5/27/2007] [9:31:16 PM] App: C:\Program Files\InfinityBox\Moto01\Moto01.exe Loading data, wait... [Infinity Box] v1.39 S/N: ***REMOVED*** Current model: C113(a),C114,C115,C116,C117,C118 Ready Current model: C139,C140 COM1 selected Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 1.0.24 HW version: _E88 LP ver: LPN_C139_NA2_00X Flex ver: FFN_C139_4R_10X imei otp: ***REMOVED*** Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_***REMOVED***_20070527-213251.31E.bin imei eeprom: ***REMOVED*** Check Flash-2 Done Write... Write Done Finished, time used: 15 sec Remove/Install battery now ! |
06-01-2007, 13:41 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i dont know how, but must be boot erased check battery voltage and if it is 3,7v then in this case you have to cut test point. need to open the phone |
06-03-2007, 22:55 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It can be only one reason that phone can't power on: phone hardware damaged or empty battery. Please, open phone and check that no water inside and hardware is Ok. |
07-01-2007, 17:39 | #12 (permalink) |
Major Poster Join Date: Jan 2007 Location: Bahamas
Member: 426005 Status: Offline Thanks Meter: 0 | dear sir this might not be the right place to post this but just wondering if the motorola c139 with the new pcb type boards are able to be unlocked without having to remove cpu as yet-thanks in advance br-dagr8one |
c115 c139 problem | REALTHOMAS | Infinity-Box | 6 | 10-30-2006 23:30 |
c139 problems | guicholili | Motorola ODM | 2 | 09-22-2006 00:49 |
Motorolla C139 problem unlocking.. Help!!! | arimob | Smart-Clip | 12 | 08-01-2006 17:05 |
c139 problem with DM tool | sq7hqi | Motorola ODM | 3 | 05-19-2006 20:46 |
C139 problem unlock with Smart Clip! | mobilplu | Motorola ODM | 6 | 04-13-2006 10:30 |
