09-02-2006, 21:26 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Age: 52
Member: 82693 Status: Offline Thanks Meter: 12 | C139.....still Dead After Complete Flashing. the phone is still dead.....pls help mr.infinity supporter....how can i bring this phone back to live? here is the log file: COM5 selected Action: Flash Write: Firmware Write: Flex Write: Language Pack Skip: Eeprom "Smart Write" active Device: C139 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW ver: 1.0.03.E. HW ver: MOTOROLA_E88 LP ver: Flex ver: FFE_C139_28_00A Check Flash-1 Done Check Flash-2... Check Flash-2 Done Write... Writing: Firmware File/Phone "Firmware" version the same: 1.0.03.E.ÿÿÿÿ continue: Firmware Writing: Flex Writing: Language Pack Write Done Finished Remove/Install battery now ! Time used: 55 sec plsssssss help....... |
09-03-2006, 09:41 | #5 (permalink) |
Member: 82693 Status: Offline Thanks Meter: 12 | 1.battery fully charged 2."smart write" disabled 3.other flash files used all to no avail..................... log here...... COM5 selected Action: Flash Write: Firmware Write: Flex Write: Language Pack Skip: Eeprom Device: C139 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW ver: 1.0.03.E. HW ver: MOTOROLA_E88 LP ver: LPE_C139_EMEA_T12_00A Flex ver: Check Flash-1 Done Check Flash-2... Check Flash-2 Done Write... Writing: Firmware File/Phone "Firmware" version the same: 1.0.03.E.ÿÿÿÿ continue: Firmware Writing: Flex Writing: Language Pack Write Done Finished Remove/Install battery now ! Time used: 439 sec still cofused...... |
09-03-2006, 10:07 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, Please, use OTHER flash files (not 1.0.03) ! No need to use every time the same files. If it will be no luck with other flash files I think it's need to check phone hardware. |
09-03-2006, 10:45 | #7 (permalink) |
Member: 82693 Status: Offline Thanks Meter: 12 | but now after a while,it would on by itself and write "FFS FORMATING" can i still check for the hardware or it is software........then how can i repair it? thanx in advance. |
09-03-2006, 11:15 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | "FFS FORMATING" message have to disappear after some time. If you see this message on LCD for very long time - you have a reason to check phone hardware (f.e. rehot flash chip etc.) |
09-10-2006, 12:41 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Repair eeprom files for C139 was uploaded today in support area. Try to flash different eeprom files in your phone. If it will be no luck after this procedure - check phone hardware. |
Still Dead After Complete Format | alamgarh | Infinity-Box | 2 | 01-25-2010 20:42 |
q380 dead after complete flash still dead | bhoybits99 | PadFinder box | 1 | 12-21-2008 11:45 |
J600v Dead After Complete Flash !! | Software Centre | UST Pro II | 12 | 07-28-2008 08:48 |
k750i Dead After Complet flash ! | ti_zana | Cruiser Suite | 8 | 01-05-2007 21:20 |
C139 Still Dead After Perfect Flashing | HAROON's | Infinity-Box | 6 | 07-17-2006 16:16 |
