09-02-2011, 11:39 | #1 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1632206 Status: Offline Thanks Meter: 7 | C139 SW version: 9.2.17 LIKE THIS.. Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 9.2.17 HW version: _E88 LP ver: LPN_C139_NA_T0H Flex ver: FFN_C139_TP_T0H imei otp: 011481005187579 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\InfinityBox\Moto01\backup_eeprom_calibration_01 148100518757 OPPSS FLASHING USING THIS FLASH DONE STEP BY STEP Code: COM2 [VCP2] selected "repair mode" active "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 9.2.17 HW version: _E88 LP ver: LPN_C139_NA_T0H Flex ver: FFN_C139_TP_T0H imei otp: 011481005187579 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\InfinityBox\Moto01\backup_eeprom_calibration_011481005187579_20110902-174034.31E.bin imei eeprom: 011481005187579 Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Write Done Finished, time used: 356 sec Remove/Install battery now ! COM2 [VCP2] selected "repair mode" active Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... startup condition detected SW version: 1.3.29 HW version: _E88 LP ver: LPH_C139_ASIA2_Z1C Flex ver: FFH_C139_67_Z1C imei otp: 011481005187579 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\InfinityBox\Moto01\backup_eeprom_calibration_01 148 1005187579_20110902-175013.31E.bin imei eeprom: 011481005187579 extra method pass-1... reading ... extra method pass-2... Check Flash-2 Done Write... Write Done Finished, time used: 85 sec Remove/Install battery now ! |
