08-01-2009, 17:35 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | c139 tracfone 8.8.17 boot problem solved i was not able to flash this c139 tracfone 8.8.17 .........after many tries i use this software to write new boot then i flashed it easyly with infinty then unlock and at last then modify to 900mhz with attached pic COM4 [VCP0] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 8.8.17 HW version: _E88 LP ver: LPN_C139_NA_T0H Flex ver: FFN_C139_TP_T0H imei otp: 011098004392719 Check Flash-1 Done Check Flash-2... reading ... file saved: E:\InfinityBox\Moto01\backup_eeprom_calibration_01 1098004392719_20090801-221152.31E.bin imei eeprom: 011098004392719 Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Write Done Finished, time used: 123 sec Remove/Install battery now ! ---------------------------------------------------------- Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 1.0.06. HW version: _E88 LP ver: LPL_C139_LATAM_00F Flex ver: FFL_C139_3S_10F imei otp: 011098004392719 Check Flash-1 Done Check Flash-2... reading ... file saved: E:\InfinityBox\Moto01\backup_eeprom_calibration_01 1098004392719_20090801-221528.31E.bin imei eeprom: 011098004392719 Check Flash-2 Done Write... Write Done Finished, time used: 19 sec Remove/Install battery now ! Last edited by zeerik; 08-01-2009 at 17:37. Reason: xxxxxx |
The Following 5 Users Say Thank You to zeerik For This Useful Post: |
C139 tracfone V9.2.17 | budaw | Motorola Hardware Repair | 0 | 04-09-2009 02:12 |
C139 8.8.17 TracFone | geohot | Motorola ODM | 42 | 01-18-2009 21:30 |
motorola c139 tracfone v8.8.17 | lacasapc | Infinity-Box | 11 | 09-26-2007 17:42 |
c139 version 8.8.17 tracfone | a.z | Infinity-Box | 0 | 06-09-2007 09:43 |
C139 Tracfone with s/w ver 8.8.17...need help flashing | pvfjr | Motorola ODM | 1 | 12-15-2006 23:38 |
