07-10-2007, 04:27 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Sun Age: 44
Member: 4021 Status: Offline Thanks Meter: 782 | c139 tracfone after removing N1 ball.. flashing problem kindly check the image.. is this the right flashing logs?? i removed th N1 ball coz its a new type of PCB... but after reinstalling the cpu, i flashed it with 1.xxxx flash files now im getting that result in flashing.. is that right? i also put check on cutted track before flashing... please guide me.. thanks alot! |
07-11-2007, 11:47 | #4 (permalink) |
Member: 4021 Status: Offline Thanks Meter: 782 | here is the log... kindly check please Code: Finished, time used: 57 sec Remove/Install battery now ! COM1 selected "repair mode" active "smart write" active "soft restore" active Action: flash Write: Firmware Write: Flex Write: Language Pack Skip: Eeprom Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... startup condition detected SW version: 1.0.01.E. HW version: _E88 ROLA LP ver: LPN_C139_NA_T0H LPN_C139 Flex ver: ,LOC F 112 911 imei otp: 010968009070808 Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_010968009070808_2007-7-9_19-47-40.31E.bin Check Flash-2 Done Write... Writing: Firmware file/phone "Firmware" version the same: 1.0.01.E. continue: Firmware startup mode adjusted retry[01] at: 00000000 retry[02] at: 00000000 retry[03] at: 00000000 retry[04] at: 00000000 retry[01] at: 00010000 retry[02] at: 00010000 retry[03] at: 00010000 retry[04] at: 00010000 retry[01] at: 00020000 retry[02] at: 00020000 retry[03] at: 00020000 retry[04] at: 00020000 retry[01] at: 00030000 retry[02] at: 00030000 retry[03] at: 00030000 retry[04] at: 00030000 retry[01] at: 00040000 retry[02] at: 00040000 retry[03] at: 00040000 retry[04] at: 00040000 retry[01] at: 00050000 retry[02] at: 00050000 retry[03] at: 00050000 retry[04] at: 00050000 retry[01] at: 00060000 retry[02] at: 00060000 retry[03] at: 00060000 retry[04] at: 00060000 retry[01] at: 00070000 retry[02] at: 00070000 retry[03] at: 00070000 retry[04] at: 00070000 retry[01] at: 00080000 retry[02] at: 00080000 retry[03] at: 00080000 retry[04] at: 00080000 retry[01] at: 00090000 retry[02] at: 00090000 retry[03] at: 00090000 retry[04] at: 00090000 retry[01] at: 000A0000 retry[02] at: 000A0000 retry[03] at: 000A0000 retry[04] at: 000A0000 retry[01] at: 000B0000 retry[02] at: 000B0000 retry[03] at: 000B0000 retry[04] at: 000B0000 retry[01] at: 000C0000 retry[02] at: 000C0000 retry[03] at: 000C0000 retry[04] at: 000C0000 retry[01] at: 000D0000 retry[02] at: 000D0000 retry[03] at: 000D0000 retry[04] at: 000D0000 retry[01] at: 000E0000 retry[02] at: 000E0000 retry[03] at: 000E0000 retry[04] at: 000E0000 retry[01] at: 000F0000 retry[02] at: 000F0000 retry[03] at: 000F0000 retry[04] at: 000F0000 retry[01] at: 00100000 retry[02] at: 00100000 retry[03] at: 00100000 retry[04] at: 00100000 retry[01] at: 00110000 retry[02] at: 00110000 retry[03] at: 00110000 retry[04] at: 00110000 retry[01] at: 00120000 retry[02] at: 00120000 retry[03] at: 00120000 retry[04] at: 00120000 retry[01] at: 00130000 retry[02] at: 00130000 retry[03] at: 00130000 retry[04] at: 00130000 retry[01] at: 00140000 retry[02] at: 00140000 retry[03] at: 00140000 retry[04] at: 00140000 retry[01] at: 00150000 retry[02] at: 00150000 retry[03] at: 00150000 retry[04] at: 00150000 retry[01] at: 00160000 retry[02] at: 00160000 retry[03] at: 00160000 retry[04] at: 00160000 retry[01] at: 00170000 retry[02] at: 00170000 retry[03] at: 00170000 retry[04] at: 00170000 retry[01] at: 00180000 retry[02] at: 00180000 retry[03] at: 00180000 retry[04] at: 00180000 retry[01] at: 00190000 retry[02] at: 00190000 retry[03] at: 00190000 retry[04] at: 00190000 retry[01] at: 001A0000 retry[02] at: 001A0000 retry[03] at: 001A0000 retry[04] at: 001A0000 retry[01] at: 001B0000 retry[02] at: 001B0000 retry[03] at: 001B0000 retry[04] at: 001B0000 retry[01] at: 001C0000 retry[02] at: 001C0000 retry[03] at: 001C0000 retry[04] at: 001C0000 retry[01] at: 001D0000 retry[02] at: 001D0000 retry[03] at: 001D0000 retry[04] at: 001D0000 retry[01] at: 001E0000 retry[02] at: 001E0000 retry[03] at: 001E0000 retry[04] at: 001E0000 retry[01] at: 00230000 retry[02] at: 00230000 retry[03] at: 00230000 retry[04] at: 00230000 Writing: Flex retry[01] at: 00310000 retry[02] at: 00310000 retry[03] at: 00310000 retry[04] at: 00310000 retry[01] at: 00320000 retry[02] at: 00320000 retry[03] at: 00320000 retry[04] at: 00320000 retry[01] at: 00330000 retry[02] at: 00330000 retry[03] at: 00330000 retry[04] at: 00330000 retry[01] at: 00340000 retry[02] at: 00340000 retry[03] at: 00340000 retry[04] at: 00340000 retry[01] at: 00350000 retry[02] at: 00350000 retry[03] at: 00350000 retry[04] at: 00350000 retry[01] at: 00360000 retry[02] at: 00360000 retry[03] at: 00360000 retry[04] at: 00360000 Writing: Language Pack retry[01] at: 00240000 retry[02] at: 00240000 retry[03] at: 00240000 retry[04] at: 00240000 retry[01] at: 00250000 retry[02] at: 00250000 retry[03] at: 00250000 retry[04] at: 00250000 retry[01] at: 00260000 retry[02] at: 00260000 retry[03] at: 00260000 retry[04] at: 00260000 retry[01] at: 00270000 retry[02] at: 00270000 retry[03] at: 00270000 retry[04] at: 00270000 retry[01] at: 00280000 retry[02] at: 00280000 retry[03] at: 00280000 retry[04] at: 00280000 retry[01] at: 00290000 retry[02] at: 00290000 retry[03] at: 00290000 retry[04] at: 00290000 retry[01] at: 002A0000 retry[02] at: 002A0000 retry[03] at: 002A0000 retry[04] at: 002A0000 retry[01] at: 002C0000 retry[02] at: 002C0000 retry[03] at: 002C0000 retry[04] at: 002C0000 Write Done Finished, time used: 1816 sec Remove/Install battery now ! ---------------- |
07-11-2007, 12:39 | #6 (permalink) |
Member: 4021 Status: Offline Thanks Meter: 782 | so is it possible that i damaged the chip already?? if ever it is damage.. can i get from other phones and replace it? i reballed it thrice already but still the same result.. thanks for your reply! |
Flash and Unlock for C139 Tracfone phones firmware version 1.9.20 and 1.9.24!!! | Denis | Main Sales Section | 0 | 07-25-2008 21:06 |
When C139 tracfone new flash type will be supported... | harim_1981 | Smart-Clip | 3 | 01-13-2008 16:14 |
C139 Tracfone unlock problem | rajumobile | Smart-Clip | 3 | 11-07-2007 22:29 |
c139 tracfone flash flex fail | mrfixit | Infinity-Box | 1 | 03-06-2007 10:03 |
C139 Tracfone with s/w ver 8.8.17...need help flashing | pvfjr | Motorola ODM | 1 | 12-15-2006 23:38 |
