C139 unlock problem this is what i get when trying to unlock this model Action: Unlock Device: C139 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... Set Baud Done Check Flash-1... SW Ver: 1.0.02.E. HW Ver: MOTOROLA_E88 Check Flash-1 Done Check Flash-2... In progress... Err: non-locked or unknown eeprom Check Flash-2 Fail Finished Remove/Install battery now ! Time used: 44 sec always stop at 75% any suggestion:confused: brgds meneleo |
try using different battery that has a much stable capacity.....it happened to me before but managed to unlock the phone after replacing the battery wbr |
yes boss darie.im using full bar battery tried with latest version 1.16A this is the result COM1 selected Action: Unlock Device: C139 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW Ver: 1.0.02.E. HW Ver: MOTOROLA_E88 Check Flash-1 Done Check Flash-2... In progress... File saved: Backup_eeprom-1__2006-5-29_14-8-11.31E.bin Err: non-locked or unknown eeprom Check Flash-2 Fail Finished Remove/Install battery now ! Time used: 27 sec phone still lock im using com 1 cable because not working with infinity cable port settings is okey brgds meneleo |
Are you sure that your phone sp-locked ? if yes: power on/off phone and try direct unlock again or try to read codes. if not helps: read flash and send to [email protected] |
enjoy and be happy valid for others :Motorola: C113, C115, C115i, C116, C117, C118, C139, etc,,.... go folder data and get the codes.. the first 8 digits from left to right - br sm4rtboy |
brgds meneleo |
there is an error in reading flash brgds meneleo |
What is the error during flash reading ? Log ? |
try to check the 3pin cable and if thats ok attach serial cable from pc to infinity box (here i used com 1 & the orig 3pin cable from infinity) then try to unlock again....i used infinity for almost all c139 unlocking though free soft would do but as an infinity box user we always trying all possibilities utilizing this |
by the way, the phone is in "simlock contact service provider" when the customer handled it to me.this means that it is simlock to Smart and tried using simcard from other provider and entering wrong codes resulting to not accepting any simcard.upon trying to read codes and direct unlock which having some failed, the phone accept simcard from the original provider:) but it is still simlock to other network:D will post again as soon as customer come back. brgds meneleo |
brgds meneleo |
Hi, please, send me file "Log_moto01.txt". This file located with folder with software. All operations history saved in this file. [email protected] |
sorry, not seen that auto log was created brgds meneleo |
@meneleo used the appropriate cable mate (C139 Cable).. all the operations you've done is OK, i think the only problem is in your cable... br |
Try to read flash again. Aslo send me eeprom backup files ("backup...." files in folder with software) |
